SOLD — RS4 B7 Saloon Phantom Black RS04 RAW - MRC Stage 2
Posted: Mon Jul 22, 2019 12:29 am
2006 (56) Phantom black saloon
74,100 miles with Full Audi/MRC service history
A well documented example know by many on this forum with a great factory spec and some modifications which only add to the experience
Spec:
Black silk nappa Leather
Heated bucket seats
Front centre armrest
Flat bottomed RS4 steering wheel
Carbon fibre interior trim
Solar sunroof
Bluetooth
Bose sound upgrade
Adaptive xenon headlights (cornering whilst steering)
Clear front indicator lens
Front fog lights
Auto dimming rear view mirror
Light and Rain Sensor
Climate Control
Factory fitted Electric rear blind
Factory fitted Rear window blinds
ISOFIX rear seats
Cruise control
Power assisted steering
Remote Central Locking
Front and rear parking sensors
Electric heated door mirrors
ABS
Electronic Stability Program
Modifications:
Ported, polished & cleaned inlet manifold
Milltek straight through non res/non valved exhaust system from headers back
- OEM Cats available if required
MRC Cold Air Feed
Tarox front discs, ferrodo ds2500 pads
OEM brembo pads and OEM discs on rear
Stainless Steel brake lines with RBF600 fluid
KW v3 Coilovers
H&R anti rollbars
JHM LWFW + OEM clutch
JHM Short Shifter
JHM Intake Spacers
MRC Stage2 custom remap (445ps / 465nm)
Led number plate lights
RS Logo puddle lights
3G RNS-E Retrofit
- Audi Music Interface (USB, 500GB Hard drive, Bluetooth Streaming)
- Higher definition screen
- Faster user interface
- Voice control button added to dash
Security:
Clifford G5 alarm and immobiliser with blackjax
Service history:
(All paperwork dating back to original owner is recorded and retained)
Date. Odometer Garage Cat Scope
07/01/2008 11,006 Audi Service Oil, pollenFilter
23/09/2008 16,256 Audi Service Brake Fluid
27/03/2009 19,106 MRC Service Oil, AirFilter, spark plugs, pollen filter, Carbon clean
15/06/2009 22,560 MRC Service Oil Service
10/09/2009 23,735 MOT MOT
06/02/2010 28,481 MRC Service Oil, BrakeFluid, Carbon Clean
29/06/2010 33,783 MRC Service 10k Service, Oil, Clutch
31/08/2010 38,028 MOT MOT
14/09/2010 38,782 JJB Service Oil
09/03/2011 41,358 MRC Service Oil, SparkPlugs, BrakeFluid, CarbonClean, FuelFilter
06/09/2011 45,370 MOT MOT
18/04/2012 49,377 MRC Service Oil, Pollen Filter, 10k Service
30/08/2012 51,634 MOT MOT
03/09/2013 54,999 MOT MOT
02/05/2014 59,718 MRC Service 60K service, Oil, SparkPlugs, AitrFiltr, Pollen Filter, FuelFilter, gearbox and diff oil replaced
28/08/2014 62,144 MOT MOT
16/02/2015 64,242 ClayMotors Service Oil Service
16/03/2015 64,522 KwikFit Service Aircon recharged
05/09/2015 65,827 MOT MOT
16/11/2015 66,147 Audi Service Oil, BrakeFluid
16/08/2016 67,344 MOT MOT
28/11/2016 67,800 DirectAutoRepairs Service Clutch Kit, Slave Cylinder, Master Cylinder
20/09/2017 68,811 MOT MOT
20/09/2017 68,811 Direct Motors Service Oil Service
22/08/2018 70,089 MRC Service 10k service, Oil, Air Filter, Pollen Filter, Carbon Clean, Lambda Sensor 2
04/10/2018 70,458 MOT MOT
Condition:
Bodywork - Free of dents and dings across all panels. No major scratches and the occasional wash related marring could be detailed out. The lower front end and forward facing arch does show stone related marking which is to be expected of its mileage and more obvious on black paint. There is small under paint bubble on the edge of the front arch where it meets the arch liner. Chrome trim on rear boot entry and front end were recently replaced (58k and 64k) and only the trim around the doors shows slight milking common on the B7
Wheels - Refurbed 3 years ago and have no kerbing related marks. There are a few stone chops and some minor under surface corrosion showing
Tyres - Goodyear Eagle F1 275’s which have been recently rotated so now with (v. approx) 6mm front and 5mm rear even wear across the tyre and no cuts or bulges
Brakes - Recent caliper refurb (Aug 2018 / 69k) and remain in great condition. Pads are at around 80% rear and 70% front. Discs will need replacing with the next set of pads
Suspension - I recently (68k) raised the ride height of the KW v3 coilovers as I wasn’t keen on the arch overlapping the wheel as set by the previous owner and along with this a 4 wheel alignment and health check was completed with no issues to report
Interior - I’d say after seeing quite a few others the interior is in the top 5% in terms of condition. Wear levels on the leather are very low and bolsters are not deformed or showing wear. No interior parts are broken or scratched. In 2015 @ 60k the lower steering trim replacement means the most common wear item is as new. Comes with 3 sets of mats (show/daily/winter). Recent repair to the armrest clip and glovebox damper means all the usual known weak points on the interior have been addressed
Electrical - I have recently corrected a simple wiring issue with the radio which caused it to not illuminate with the headlights and not show in the DIS which was the only electrical issue I found. It starts single press on the start button without delay on a cold start so all relays and related switch gear are good. Bluetooh works perfectly with my iPhone 8 for both calls and music streaming
Its been a joy to get the chance to drive a car of this spec as each of the modifications add a real edge to the car over my previous sprint blue avant which was mainly stock. The exhaust is perfect and my initial fears of it being overly loud were dispelled on the first journey and the mechanical feel of the shifter being spot on with the extra weight the jhm kit adds. Throttle response and torque remind just how good this engine can be and backed up with the brake line and pad upgrades the braking system matches the engines pace with great feel and assurance . This is how I want my next B7 to be only avant form again, sad to think Audi won’t produce a car like this again. This hit home the day I let my son start the car and the look on his face made me realise the cars of his generation might not evoke the same emotions at startup
Huge respect has to go out to the previous owners as it wouldn’t have been in this condition after this time without some serious care and attention.
Let me know if there are any other details that are needed or any general questions on the car. I'm based in Glasgow, Scotland and can happily do a FaceTime/WhatsApp video call for those further afield to show you around the car.
Asking price is £16495 ono
Spec:
Heated bucket seats
Solar sunroof
Bluetooth
Bose sound upgrade
Front fog lights
Climate Control
ISOFIX rear seats
Cruise control
ABS
Modifications:
MRC Cold Air Feed
KW v3 Coilovers
H&R anti rollbars
JHM Short Shifter
JHM Intake Spacers
3G RNS-E Retrofit
Security:
Service history:
Condition:
