Dam slight knock
Posted: Sat Apr 26, 2025 9:47 pm
by Neilb76
Ok got this dam slight knock on when setting off and coming to a stop. Even when I turn slightly. Going over bumps and normal driving it's absolute fine. Only when I stop or set off
It's in kw coilovers so it's not the DRC
Had all the arms changed so they ate new checked everything is tight inc the suspension top mounts
Re: Dam slight knock
Posted: Mon Apr 28, 2025 9:19 am
by AndyBrad
Ive had exactly the same issue. (running kw v3)
replaced all the arms etc and still had it. its settled down in a few months.
thought it could be the top mounts, I think half of it was a loose undertray and also pads in the caliper.
Posted: Mon Apr 28, 2025 9:04 pm
by Neilb76
AndyBrad wrote: ↑Mon Apr 28, 2025 9:19 am
It's just wired got it booked in this week at the garage to have a look. Nothing is loose that i can see. So will see what happens
Posted: Tue Apr 29, 2025 8:47 am
by AndyBrad
One thing to note.
When i had all the front arms replaced they didnt use new bolts initially. This caused a clunk going from forward to reverse.
squeaking is top mounts.
I had a rattle that i thought was the suspension and after months of fettling it turned out to be the dash panel under the bonnet.
Posted: Thu May 01, 2025 8:25 am
by AndyBrad
oh is it through the fotwell?
Posted: Sat May 03, 2025 9:42 am
by Neilb76
AndyBrad wrote: ↑Thu May 01, 2025 8:25 am
Yes
Posted: Sat May 03, 2025 9:45 am
by Neilb76
AndyBrad wrote: ↑Tue Apr 29, 2025 8:47 am
One thing to note.
It came with all new nuts and bolts etc, the garage still could not find anything loose
Posted: Mon May 05, 2025 3:54 pm
by AndyBrad
ah. replace the lower inner bolts and torque to spec. Thats what solved mine.
Posted: Mon May 05, 2025 8:05 pm
by Neilb76
AndyBrad wrote: ↑Mon May 05, 2025 3:54 pm
Sorry for being dumb which are them, lower wishbone inner ?
Posted: Tue May 06, 2025 3:13 pm
by AndyBrad
yea thats what helped with mine. The bolts were stretched.
