B8 RS4 ('14 plate) - Opinions/thoughts?
Posted: Tue Jul 16, 2024 2:46 pm
Hi all,
I'm a new member here since I am hoping to soon become an RS4 owner. Trying to avoid buying a lemon though that will make the whole ownership a regrettable one, I'd like to get your opinion on the car's history.
The car has:
Date | Miles | Cost | Work
As you can imagine my main worry is what exactly happened with the final drive when after having proper servicing and oil changes it ended up needing replacement. Also the car has a few advisories on low tread on tyres but cant figure out if owner just ignored advisories or also relates to the final drive
Appreciate this is a bit of a long one but keen to hear thoughts
The car has:
- 75849k miles
- 2 owners 2014-2016 and 2016-now (1 of which it may be Audi themselves as a test drive car).
- Full service done in Audi (I phoned them up and have confirmed that)
- 12 months warranty (labour + parts) from the seller that can be implemented at any VAT-Registered garage in the UK
- 27/12/23 | 73,404 | £0 | Health Check
- 27/12/23 | 73,398 | £11,200 | Carried out replacement of final drive
- 15/11/23 | 73,063 | £1,600 | MOT, AVS, osr puncture repair, nsf curved arm bush, rear diff seals, wipers, light indicator
- 15/11/22 | 63,874 | £813 | MOT, oil and filter, HC, x2 front tyres, headlamp adjustment
- 13/01/22 | 62,806 | £2,500 | FBDP/RBDP (assuming this means brake discs + pads)
- 29/11/21 | 61,764 | £817 | Straight lower inner suspension bushes, x2 tyres wear
- 16/11/21 | 61,642 | £900 | AVS, MOT, Front final drive oil
- 07/10/21 | 61,282 | £140 | Seatbelt buckle
- 29/10/19 | 42,926 | £250 | AVS
- 06/05/19 | 42,442 | £400 | MOT and brake pad harnesses
- 08/02/19 | 41,296 | £220 | N/S headlamp bulb
- 03/10/18 | 39,082 | £750 | AVS/S-Tronic/Front & Rear diff oils & rear final drive oil
- 16/07/18 | ------ | £36 | Swap drive shafts
- 14/06/18 | 36,734 | £240 | N/S/F when bearing C proctor
- 28/05/18 | 36,360 | £0 | Wheel bearing noise
- 14/05/18 | 36,178 | £1,300 | Front & rear pads front discs/wiper blades
- 23/04/18 | 32,597 | £67 | MOT & Bulb
- 07/08/17 | 28,850 | £250 | AVS
- 16/05/17 | 27,716 | £50 | MOT
- 28/12/16 | 24,446 | £85 | Not RO tyres on vehicle
- 17/08/16 | 24,416 | £113 | Replaced number plate plinth
- 22/06/16 | 24,353 | £216 | MPI, plates
- 24/05/16 | 23,340 | £189 | oil & filter
- 29/02/16 | 20,440 | £120 | 4 wheel alignment
- 29/02/16 | 20,440 | £419 | replaced front left suspension flexible pipe, modified boot struts
- 28/01/16 | 18,897 | £365 | inspection, final drive oil
- 28/01/16 | 18,897 | £50 | Wipers
- 25/01/16 | 18,897 | £540 | N/S/F absorber & o/s/f door Bowden cable C proctor
- 25/01/16 | 18,897 | £400 | inspection, final drive oil
- 17/07/15 | 14,201 | £190 | oil and filter change service
- 09/12/14 | 7,000 | £1,000 | replaced front discs & pads, replaced pistons in front calliper
- Audi Service | 2023-11-20 | 73059mi | Inspection with oil change (flexible)
- Audi Service | 2022-11-15 | 68730mi | Oil change service
- Audi Service | 2021-11-16 | 61638mi | Inspection with oil change (flexible)
- Audi Service | 2021-05-10 | 58365mi | Additional work
- Audi Service | 2021-05-10 | 58365mi | Oil change service
- Audi Service | 2019-11-04 | 43920mi | Inspection with oil change
- Audi Service | 2018-10-08 | 39076mi | Inspection with oil change
- Audi Service | 2017-08-10 | 28844mi | Inspection with oil change (flexible)
- Audi Service | 2016-05-27 | 23340mi | Flexible oil change service
- Audi Service | 2016-01-26 | 18889mi | Inspection
- Audi Service | 2015-07-17 | 14201mi | Flexible oil change
- Audi Service | 2014-05-13 | 38mi | Delivery inspection
