Tyre pressure sensors
Posted: Sat Feb 25, 2023 9:49 am
by MGD
Hello
Does anyone have any experience of tyre pressure warning going off when tyres are all seemingly ok?
It’s a recurring issue after I’ve driven for a few miles that it goes off. I’ve been checking the tyres regularly and the pressures have been consistent.
Tyres were done a couple of years ago and have plenty of tread.
Do the pressure sensors need replaced periodically? I’ve heard that on VAG vehicles the batteries for each sensor need replaced - is that the case here?
Thanks in advance for any guidance.
Matt
Re: Tyre pressure sensors
Posted: Sat Feb 25, 2023 6:36 pm
by stuartbarriskell
Doubt the batteries are replaceable Matt, likely a new sensor required, someone with direct knowledge will likely be of more help on this..
FWIW any sensors I've done in the past were swap out job's, that was on one bike and My VW Touareg.
Sent from my SM-S918B using Tapatalk
Posted: Sat Feb 25, 2023 6:55 pm
by MGD
Thanks Stuart,
I suspect you’re right. The possibility of a cheap and easy fix on these is highly doubtful :p
Posted: Sat Feb 25, 2023 7:48 pm
by stuartbarriskell
MGD wrote:Thanks Stuart,
Agreed, there's nought cheap on these, pretty sure I bought my last full set from here..
https://tpmswarehouse.co.uk/product/aud ... itor-tpms/
Worth a
Shop around online, done a quick scan, check these out .
https://www.ebay.co.uk/itm/155389234690 ... media=COPY
Posted: Sat Feb 25, 2023 9:12 pm
by MGD
Thanks Stuart,
Looks like they only have sensors for B7 or B9. It’s in for service and mot soon so will hang fire before doing anything.
Posted: Sat Feb 25, 2023 9:50 pm
by stuartbarriskell
Plenty online, don't think I'd be that precious about OE, loads of aftermarket at considerably less moolah
Posted: Sun Feb 26, 2023 2:20 pm
by MJ_RS4
Hi guys,
Happy to be proved wrong but I don’t think the B8 has these types of tyre pressure sensors, rather it uses the rolling circumference to detect an issue rather than the specific pressure within each tyre.
Cheers,
Matt
Posted: Sun Feb 26, 2023 5:04 pm
by stuartbarriskell
MJ_RS4 wrote:Hi guys,
Cheers,
Matt
I assumed they were bog std TPMS senders. Your hypothesis sounds much more interesting MJ
... be good to know.
Posted: Sun Feb 26, 2023 6:11 pm
by MGD
Thanks Matt,
I’ll see what the craic is when it goes in to the garage and let you know.
