Dip stick oil levels
Posted: Thu May 27, 2021 12:00 pm
by Scammo1
Does anyone know the quantity of oil represented between the min and max marks on the virtual dipstick?
Am guessing about a litre but that is a complete guess!
Re: Dip stick oil levels
Posted: Sat May 29, 2021 3:40 pm
by 114uyc
I think it’s 3/4 of a litre, let Google be your friend
Posted: Fri Jun 04, 2021 1:41 pm
by Astonished
1 litre took it from “just at minimum” to “just full”
But ... the system did say I could put in up to 1.5 litres
That was 3 days ago .. so fresh in my mind
Posted: Sat Jun 05, 2021 8:52 pm
by Scammo1
Posted: Tue Jul 06, 2021 8:35 am
by Rs4nutter
Is there an actual dip stick on these engines? And where/how easy is it to access?
Posted: Tue Jul 06, 2021 3:23 pm
by johnnydog
I believe there is a dipstick hole situated on the left hand front of the block (obviously!
) - right hand side if looking at the engine. The plastic trim has to be removed to access it, and it is plugged - intended for a workshop manual dipstick check if necessary. Dealers have a dipstick with different capacity markings for different vehicles solely for manual checks.
I only believe this is correct as I watched an RS5 of the same era as the B8 RS4 having its level checked manually at a dealership, so I presume the RS4 is the same.....but will stand corrected of course!
Posted: Tue Jul 06, 2021 3:43 pm
by johnnydog
I believe this plastic intake has to come off and the access to the dipstick hole is underneath.
Posted: Tue Jul 06, 2021 8:45 pm
by Rs4nutter
Cheers johnnydog, may have a look, if have share day to take trims off!!
Posted: Wed Jul 07, 2021 12:25 pm
by johnnydog
Assuming that you find the bung for the dipstick hole, don't forget you'll need an actual dipstick of the correct length and level markings. There won't be one in the block.
Posted: Wed Jul 07, 2021 9:35 pm
by Rusty Racer
Sounds like a right faf!
Posted: Mon Jul 12, 2021 6:57 pm
by Rs4nutter
Found it, got rubber bung on top, couldn’t be bothered to take air inlet cover off
Posted: Mon Jul 12, 2021 11:58 pm
by johnnydog
Good to confirm at least that the RS4 actually has one as well as the RS5
