Reverse Camera Module - Error
Posted: Mon Jul 15, 2019 10:17 am
Hi Guys,
My reverse camera module went kaput due to water damage. It is located in the rear offside wheel well. Long story short, the main diode had corroded through, I had a new one fitted and the problem still persists. Essentially the parking icon can be selected but it just emits one long beep and the camera screen does not come up. Again this happens when you select reverse. The sensors all work fine, but no screen depiction. If you quick reset the MMI you can get the parking aid screen up, but it is just blank where the camera view should be.
I've now fitted a brand new module, but the system will still not function. I can now select the parking menus through the MMI, which I could not before, to select volume and intensity for the parking sensors, but the reverse camera view still does not come up.
Does anyone know if the system needs to be reset or configured for the new module? And/Or if anyone in the Manchester area can help out with their VCDS?
Many thanks in advance,
Chee
Chee
