So after driving across grass fields again I figured it was time for an update and duly purchased the 2019 map via a mate in TPS.
Got home, found the MMI setup menu and selected update but after numerous attempts the sd card can’t be found?
It’s looking like I now require a firmware update also as it may be the original in the car still. Has anyone else come across this, I would appreciate a recommendation for a company who knows what they are doing
2014 sat nav update
2014 sat nav update
2018 RS4 B9 Carbon Edition
2014 RS4 B8
2014 RS4 B8
Re: 2014 sat nav update
Ended up with wrong map so after getting the right one it’s all sorted FYI
2014 RS4 B8
2014 RS4 B8
How much was the SD? I have been trying to do this for some time....
Just over a couple of hundred iirc. Most important thing is to get your current nav details off the car and then get the correct map
2014 RS4 B8
2014 RS4 B8
Where did you get the SD card from, Audi are quoting be over £300 to update the sat nav
TPS but unsure of their current retailing policy (they might not be willing to sell to you).
Tbh it was a massive pita and I ended up back at the dealer after I had eaten a big slice of humble pie!
If you go to the dealer they should also update the firmware version and now I guess you get a 2020 map
2014 RS4 B8
2014 RS4 B8
I upgraded my firmware and maps in November using these guys with no problems:
https://upgrademyaudi.net/tutorials/upd ... -firmware/
Sensible money for the upgrade. If you follow their guide to the letter works a treat. Did take an hour or two to upload into the MMI. Adam is very helpful if you get stuck.
RS4 (B8), Solar Orange, Sports & Carbon Pack
Users browsing this forum: No registered users and 92 guests
