Service Time
Posted: Fri Feb 15, 2019 8:44 pm
by Sammyb349
So car is going in for it’s service on Monday. 4th birthday present I suppose... old girl has 22k miles on the clock
Have asked for them to address the following - should I ask about anything else?:
(1) gearbox oil
(2) A/C recharge
(3) dust & pollen filter
(4) panoramic roof service
(4) brake discs and pads
(5) brake fluid
They’ve also suggested I get the air filters replaced, but i’ve Passed as I think I might go aftermarket... any suggestions, or should I stick to OEM?
Lastly, I’d bought some Goodrich brake lines in anticipation of the brakes needing an overhaul but Audi of course won’t fit non-OEM parts.
What should I do - is it better to get discs and pads from somewhere else and get an Indy to fit them with the hoses? If yes, any recommendation in north Surrey?
Re: Service Time
Posted: Sun Feb 17, 2019 1:29 pm
by Sammyb349
Re: Service Time
Posted: Sun Feb 17, 2019 5:11 pm
by Madelvic
I'm leaning towards getting Audi to do the service work (and getting stamps in the electronic book as it were) and using an indy for non-service items
Audi prices are getting a bit crazy. I've done the service plan from them that covers two services for £595; still not that cheap but cheaper than the prices they quote.
How much are they quoting you for this work? £3365 for the work below
Service £675
Gearbox £225
Brake fluid £85
Pads and discs £1275 + £975
Sunroof £130
Re: Service Time
Posted: Sun Feb 17, 2019 5:42 pm
by Sammyb349
Thanks - Not got a quote yet off them. They will revert tomorrow once they’ve seen the car. The front pads will need doing for certain. I think discs might be okay.
If it’s just the pads then there is no point paying their prices.
Re: Service Time
Posted: Sun Feb 17, 2019 8:42 pm
by Madelvic
Wanted to change my discs - but I reckon they have 2 years left in them. Car has done 25k miles. Pads are circa £160. Get the service package if you can though - 2 services for less than what they'll charge you for one
Re: Service Time
Posted: Sun Feb 17, 2019 8:50 pm
by Sammyb349
Perfect - will look into it.
Re: Service Time
Posted: Mon Feb 18, 2019 10:36 pm
by Sammyb349
So....
Front discs and pads need doing as an advisory under the MOT. Wear sensor just about breaking through on the pads. Discs alegedly 75% worn although they didn’t give me the measurements.
Price... £1,365.
What are people’s thoughts?
Re: Service Time
Posted: Mon Feb 18, 2019 11:35 pm
by Madelvic
Need to measure disc thickness. 34mm max to 32.4mm min
Discs can be bought for £700. My Indy has just quoted £135 for pads fitted. Parts seem cheap. He thought so too
Re: Service Time
Posted: Tue Feb 19, 2019 12:43 am
by Sammyb349
Will get the disc measurements. I got a quote from Crewe Audi.
2x front discs = £732
2x Front pad sets’s = £330
Total = 1062
Re: Service Time
Posted: Mon Feb 25, 2019 9:16 pm
by Sammyb349
Time to report back...
Had the car serviced by Jack Barclay, and again it was top quality. Expensive, but for piece of mind, i’m happy. Those shiny bell rotors... :rocker:
Brake Fluid - £54
Plenum Chamber clean - £56
MOT - £49.99
Front Pads & Discs - £1,062
Oil Change Service - £264
Oil - £13.50
Oil Filter - 28.96
Pollen Filter - £46.70
Air-Con Service - £74.72
Gearbox Oil Change - £70
Gearbox Oil - £88.69
Panoramic Roof Service - £115.50
Total - £2300
:drink:
Re: Service Time
Posted: Mon Feb 25, 2019 9:19 pm
by Sammyb349
For air filter - might go aftermarket... any suggestions, or should I stick to OEM?
Re: Service Time
Posted: Mon Feb 25, 2019 9:37 pm
by Sidicks
Brake Fluid - £54
MOT - £49.99
Oil - £13.50
Oil Filter - 28.96
Total - £2300
:drink:
Looks like the £1,062 they quoted you for discs and pads was pre-VAT. That's actually a cost of £1,274.
Cheeky...
Re: Service Time
Posted: Mon Feb 25, 2019 10:13 pm
by Sammyb349
Ended up not getting the pets from Crewe Audi. Perhaps should has asked JB to match though
:bash:
Re: Service Time
Posted: Mon Feb 25, 2019 11:17 pm
by Madelvic
Weird replying to my own post, but.....
Had a Porsche Indy change front pads and front suspension parts. Cost of pads was £81 plus VAT. Wow. All in £560 including wheel alignment. Audi wanted £800 alone for the suspension work and £1300 for pads and discs
As the friendly Indy said, at that price I can change pads and discs when the discs eventually need to be done
Re: Service Time
Posted: Fri Aug 23, 2019 10:13 pm
by jangol
Just got my a few bits done this week..
Service (plugs too)
Gearbox oil
Final drive oils too..
Added new tyres also.. heavy week of spending
