Does DRC leak on the floor?
Posted: Thu Feb 07, 2019 10:11 pm
by robster
Picking up my RS4 next week, anyone got a guide on checking the DRC? Will leaks be obvious or do I need to get underneath the car to check the shocks and the steel pipes?
Re: Does DRC leak on the floor?
Posted: Thu Feb 07, 2019 11:17 pm
by dhali
In my case when it went was all over the rear diff and exhaust and floor
Posted: Fri Feb 08, 2019 12:05 am
by HB_NORM
Just had mine go on the O/S front shock. No oil on the floor, just under gator of shock and running 5 PSI.
Posted: Fri Feb 08, 2019 7:41 am
by robster
Cheers fellas, if system sealed what should the pressure read if I ask them to test it? Car from main dealer so they should have the equipment
Posted: Fri Feb 08, 2019 9:54 am
by innercry666
20 PSI.
Posted: Fri Feb 08, 2019 5:46 pm
by HB_NORM
23 PSI I was told. Guess around that mark is reasonable.
Posted: Fri Feb 08, 2019 6:14 pm
by MK2Golf24v
You are all wrong.
It’s Bar, not PSI 18-22 is the range.
Posted: Sat Feb 09, 2019 7:45 am
by robster
Cheers guys
20 bar is quite a lot pressure, hope nothing fails catastrophic
