Morning,
The left indicator warning light is showing up the dash, it’s appears the light side wing mirror indicator doesn’t light up/flash through the whole light, (just both ends)
Is that a bulb issue (if you can change them) or a wiring issue, how would I investigate you can see some mist in the picture
Left indicator warning light questions
Re: Left indicator warning light questions
I doubt there will be a bulb to change - it most likely will need the mirror indicator repeater light unit replacing. It's not difficult to do, but will need the mirror glass popping off to gain access
I'd ring your local Audi dealers parts department- I'm sure they will be able to give you the info as to whether it is a bulb or a complete repeater unit that needs replacing.
Thanks,
Will give that a go!
Ordered a replacement repeater from the steelers... will fit at the weekend
- Surrey Sam
Check the old one over and see if it's damaged, might have been done when fitting the aftermarket carbon covers?
New indicator sorted it
p’s complete carbon unit not just a cover
Users browsing this forum: Mav8 and 152 guests
