Engine Fault - Camshaft Position Sensor - Ideas?
Posted: Wed Apr 19, 2017 7:03 am
Hi All,
I've had the engine management light come on a couple of times now, it's always about a mile from home after starting the car from cold.
I hooked up to VCDS last night and pulled the following info;
Address 01: Engine (------CFSA) Labels: 079-907-560-CFS.clb
Part No SW: 8T2 907 560 E HW: 8T1 907 560
Component: 4.2l V8HDZ / H04 0003
Revision: NAH04---
Coding: 1225003225A6000A2000
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM42FSI0118T2907560E 001002
ROD: EV_ECM42FSI0118T2907560E.rod
VCID: 3E7502F0A13DAEB1DB-806A
2 Faults Found:
9032 - Camshaft Positioner (Bank 2 Exhaust)
P000D 00 [096] - Slow Response
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 39603 km
Date: 2017.04.15
Time: 08:28:01
Engine speed: 1374.00 /min
Normed load value: 16.5 %
Vehicle speed: 63 km/h
Coolant temperature: 45 °C
Intake air temperature: 8 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.418 V
Unlearning counter according OBD: 37
Engine status-Bit 0: 3
Engine oil temperature: 16.2 °C
Engine operating condition: Idling
Engine operating condition-Test_Program_Channel 87: 5
Driver-side belt buckle status-Bit 0: 104
Current system status: SYC_DRIVE
Current system status-Test_Program_Exe Con State 02 UBYTE: 4
4363 - Brake Booster Pressure Sensor
P0556 00 [096] - Implausible Signal
Readiness: 0000 0000
any ideas what could cause this fault?
Just taking the car in for a service so I'll ask Audi to report too.....
Revision: NAH04---
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 39603 km
Date: 2017.04.15
Time: 08:28:01
