Page 1 of 2
Hill Hold Assist
Posted: Sat Jul 11, 2015 6:06 pm
by Brooner
Gents any of you Vag Com Gurus know if its possible to get my 2013 B8 RS4 Hill Hold Assist button to remember the last setting i believe the 2014 onwards remember the last position after restarting the car
i have dd a bit of a trawl but nothing came up about it any help would be greatfull
just did my wife start stop function button to remember the last setting which i was originally told could not be changed so theres always a way :biggrin3:
Re: Hill Hold Assist
Posted: Sun Jul 12, 2015 7:51 pm
by carsarecool
Brooner wrote:Gents any of you Vag Com Gurus know if its possible to get my 2013 B8 RS4 Hill Hold Assist button to remember the last setting i believe the 2014 onwards remember the last position after restarting the car
I have MY14 car and it needs to be switched on every time.
Posted: Mon Jul 13, 2015 9:41 am
by RossDagley
Swear we discussed this the other day. My 2015 car remembers if I want it or not (well I presume it does, I set it once, and it's never asked me again). It disables automatically when you take your seatbelt off but when your belt is on, it's on. :) Screw having to remember to turn it on each time.
Posted: Mon Jul 13, 2015 10:37 am
by MikeFish
We did Ross, but that was in the thread about the best options to have. And it didn't say how to activate the memory feature on the 2013 cars.
Posted: Tue Jul 14, 2015 12:05 pm
by boff
Mine does it.
Is there anyway you could get VCDS to compare the settings in an MY15 car to an MY13 car?
Posted: Tue Jul 14, 2015 12:15 pm
by RossDagley
boff wrote:Mine does it.
I'll run a scan of the ABS and Cent Conv modules today from my MY15 car if someone else can do a MY13? I suspect it'll be in either of those two modules.
Posted: Tue Jul 14, 2015 6:10 pm
by Brooner
cheers
Posted: Wed Jul 15, 2015 8:44 am
by RossDagley
Scans of the most obvious modules (This is from a MY15 B8 RS4 for future reference):
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 8T0 907 379 G HW: 8T0 907 379 G
Component: ESP8 quattro H09 0010
Revision: -------- Serial number: --------------
Coding: 346DEA
Shop #: WSC 06325 000 00000
VCID: 46835BC3F184D30F83-8012
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 KH HW: 8K0 907 064 KH
Component: BCM2 2.0 H15 0711
Revision: 00002001
Coding: 05924040000000000000
VCID: 000F8DDB93203D3FF9-8054
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Component: J764 ELV MLB H40 0046
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001041659101
Coding: 0600001000749FF23D8140C3000019090F9DC70AA3090221000008004400010200020034000000
VCID: 7AFBFF33F5FC67EFB7-802E
Subsystem 1 - Part No SW: 8K2 955 119 A HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280315 H06 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B
Component: G397_RLFS H06 0004
Coding: 02005D
Subsystem 3 - Part No SW: 8K0 941 531 AQ HW: 8K0 941 531 AQ
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
Component: EHL2 V07.03 H30 0030
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 983 D HW: 8K0 920 983 D
Component: KOMBIINSTR. H35 0567
Revision: 00100000 Serial number: 67+61U74G
Coding: 33EF1100FF012600010000
VCID: 36632B038164438F13-8062
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 B HW: 8K0 907 440
Component: STS H04 0020
Revision: S0H04000 Serial number: 00000000120836
Coding: 01010101000000000001000102
VCID: 2D51046F7432005762-8078
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0363536449
Coding: 013B0E22A0B978958330023280000000
Shop #: WSC 06324 000 00000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Subsystem 2 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 3 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 4 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J245 PS151 H08 0043
Subsystem 5 - Part No SW: 8K0 959 591 C HW: 8K0 959 591
Component: J394 PS240 H08 0043
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 10000000524661
ASAM Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A7B3F33BD7CA7EFF7-806E
Posted: Sun May 08, 2016 6:35 pm
by Surrey Sam
Thanks Ross.
Mine doesn't remember the HHA status when ignition is turned off and I must admit that it’s a little frustrating, as I really like the feature and find it useful. So I'll run a VCDS check in the next day or so and compare against your coding. Mine’s an 06/14 vehicle with all the comfort access and memory seats etc - even the user manual says that it should remember the last status.
Posted: Sun May 08, 2016 6:59 pm
by Brooner
Here my same logs form 2013 car with HHA but no memory of last setting
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8T0 907 379 F HW: 8T0 907 379 F
Component: ESP8 quattro H09 0100
Coding: 346D6A
Shop #: WSC 06192 000 00000
VCID: 458AAF4ECC13D3160D-8010
Part No SW: 8K0 907 064 GE HW: 8K0 907 064 FE
Component: BCM2 2.0 H12 0633
Revision: 00002001
Coding: 01924000000000000000
VCID: 79F213BEF06B67F639-802C
Subsystem 1 - Part No SW: 8K0 959 754 CH HW: 8K0 959 754 CH
Component: FBSAUDIB8 IDG H71 0083
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Revision: 09016001 Serial number: 00000042429602
Coding: 0600001000349FF03D814083000019090F9DC70AA3090221000008004400010200020024000000
VCID: 7AF00CB2F56D6CEE30-802E
Component: WWS 080213 H06 0080
Coding: 00FD11
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Coding: 02005D
H01 0031
H01 0031
Part No SW: 8K0 920 982 J HW: 8K0 920 982 J
Component: KOMBIINSTR. H35 0556
Revision: 00300000 Serial number: UW467V81E
Coding: 23AF1100BB012600010000
Shop #: WSC 06192 123 12345
VCID: 3B7EC9B6BAD795E66B-806E
Revision: S0H04000 Serial number: 00000000076077
VCID: 2D5AF7EE74A30B56E5-8078
Revision: 00002001 Serial number: 0300861253
Coding: 013B062220B948808030023280000000
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000223867
ASAM Dataset: EV_ParkiBrake 001027
VCID: 3874D6BA83E1BEFE86-806C
I cant really see any obvious difference in the coding apart from a few letter differences
Posted: Sun May 08, 2016 7:20 pm
by S4WON
Mine is also MY 14 (14) and does not remember to keep HHA on. Id also like to keep it on
Posted: Sun May 08, 2016 7:59 pm
by kmpowell
If you have a MY14>, you need to have the convenience pack for it to remember the last setting.
Posted: Sun May 08, 2016 9:07 pm
by Surrey Sam
kmpowell wrote:If you have a MY14>, you need to have the convenience pack for it to remember the last setting.
I have both and it still doesn't remember.
Posted: Sun May 08, 2016 9:15 pm
by S4WON
I also have convenience pack..
Posted: Mon May 09, 2016 5:59 am
by kmpowell
Have you switched HHA on and saved it in the door memory button?
Edited to add, don't forget you need to have your seatbelt on for the HHA to become active.
