Page 1 of 2
Bird <beep> mark Removal
Posted: Tue May 19, 2015 8:39 am
by MK2Golf24v
How to remove Bird <beep> marks from RS paint.........
Re: Bird <beep> mark Removal
Posted: Tue May 19, 2015 12:12 pm
by daytonamart
Impressive stuff, where's it gone? did I miss something?
Posted: Tue May 19, 2015 2:54 pm
by MK2Golf24v
It was removed by heating the panel. The marks are not caused by acid etching, they are caused by temperature differences.
Posted: Tue May 19, 2015 6:51 pm
by PetrolDave
Is that a paint stripper heat gun?
Do the marks come back when the panel has cooled down to ambient?
Posted: Tue May 19, 2015 7:02 pm
by MK2Golf24v
Nope, gone permanent.
It's just a regular heat gun, garage/dit etc
Posted: Tue May 19, 2015 7:17 pm
by PetrolDave
Andy947 wrote:It's just a regular heat gun, garage/diy etc
That's what I meant, the sort of heat gun you use when stripping paint off wooden house windows, doors, skirting boards, etc.
Posted: Tue May 19, 2015 7:23 pm
by RIV
Shouldn't you put it on high heat and use a metal scraper?
Posted: Wed May 20, 2015 12:16 am
by Rallyz
About a year ago I accidentally left some bird crap on the roof of my black RS4 for a week. After finally cleaning it off there were severe marks, actually depressions in the paint. However, after a couple of weeks in the sun they completely disappeared. Autoglym had a study showing that it's heat that causes the marks rather than etching as the paint adjusts to fit the hardened bird droppings (see http://www.autoglym.com/news_articles/n ... mage-paint), so it seems that the reverse process also works, either by just leaving it in the sun like I did (although it would work better with a black car than white or silver) or by artificially applying heat.
Posted: Wed May 20, 2015 6:24 am
by bobededog
I'd never have the balls to do that to the wife's motor, never mind me own.
Posted: Wed May 20, 2015 3:07 pm
by Outtlaw
bobededog wrote:I'd never have the balls to do that to the wife's motor, never mind me own.
Snap, I'd end up putting bubbles in the paint!!
Posted: Wed May 20, 2015 6:19 pm
by carsarecool
I'm gonna give it a go.....had a dent removed today so will try at the weekend....then paint is back to perfect....
Posted: Wed May 20, 2015 6:28 pm
by RIV
Hair Dryer on high setting would be a safer bet
Posted: Wed May 20, 2015 6:55 pm
by MK2Golf24v
RIV wrote:Hair Dryer on high setting would be a safer
If you are a moron
Posted: Wed May 20, 2015 7:08 pm
by PetrolDave
If you are a moron
Take a "cool pill" and think about how hot the air is coming out of a heat gun - typically it's over 500 Celsius, which in careless hands could cause some serious paint damage.
On the other hand the air coming out of a hair dryer is typically less than 80 Celsius, which should be hot enough to remove the bird poo damage with much less risk of serious paint damage.
Posted: Wed May 20, 2015 7:20 pm
by RIV
If you are a moron
Oh you tried it first then,sorry!! :thumbs:
