Page 1 of 2
Engine troubles
Posted: Tue Jul 08, 2014 8:04 pm
by Chris-RS
Hi I'm new here,
Recently purchased a B8 RS4, and now it's in Audi having the engine removed
Story goes, I bought the car on the 10th of last month, it was a used one owner car with a clean history and 11k miles on the clock, on the 12th I headed for the LeMans 24h, car never missed a beat all the way there, however the day of my return about 70 mile from Calais the management light flashed up and the car started running lumpy, fortunately we had
Vagcom with us so scanned the car and came up with multiple misfires. My thoughts were oh great coil packs however having got recovered and the car being delivered to my local Audi dealer. They proceeded to in estivate only to find the coil packs weren't at fault and it was something much more sinister which they were trying to find out. A few days later I recieve a call to say they have found one of the exhaust valve springs has failed/snapped
so they are now in the process of pulling the engine and checking all the other valves and removing heads to check pistons and cylinder bores.
That's as far as they are at the minute I will try and keep this updated with more info as I when I get it.
Any of you guys encountered anything similar ??
Not an ideal first post granted lol.
CheeRS
Chris
Re: Engine troubles
Posted: Tue Jul 08, 2014 8:50 pm
by Graeme4130
Hi Chris
That sounds like terrible bad luck
I've personally not heard of anything similar happening in RS4/Rs5 with that engine
Hopefully Audi will deal with it very quickly for you, so keep us posted
Re: Engine troubles
Posted: Tue Jul 08, 2014 8:58 pm
by Chris-RS
Yeah it's far from ideal, thankfully it's still under warranty and my local Audi dealer has been very good so far, hopefully that continues.
Hopefully should have more info towards the weekend
Re: Engine troubles
Posted: Tue Jul 08, 2014 9:31 pm
by Graeme4130
The only thing I'd suggest you do, is get onto Audi uk about it as they're in a position to get you a decent courtesy car, as this may take done time to rectify and your dealer will probably only want to give you an A3
Re: Engine troubles
Posted: Tue Jul 08, 2014 9:39 pm
by Chris-RS
Well I'm currently away with work and not due back until end of the month so a courtesy car isn't needed at the minute but once I'm back on home soil if the car is still not ready then I shall take your advice and contact Audi UK.
Hopefully though the car will be fixed and ready for my arrival back home.
Never even thought about that tbh.
Re: Engine troubles
Posted: Tue Jul 08, 2014 11:01 pm
by RS6chris!
Is it at Teeside audi?
Re: Engine troubles
Posted: Tue Jul 08, 2014 11:41 pm
by Chris-RS
Certainly is, Infact it's still sporting the LeMans 24h
Stickers lol.
But I've got friends in the trade keeping a close eye on things for me and reporting back things that the service dept may neglect to tell me
Re: Engine troubles
Posted: Wed Jul 09, 2014 12:08 am
by Andy_S
Doesn't sound like Teesside Audi are having much luck with RS4's at the moment!
Just got mine back from them today after nearly 2 weeks to fix wonky steering...and guess what, it was fixed when I left, now wonky again
I do hope they get yours sorted on the first go. And if you need a courtesy car, definitely get on to Audi UK, other wise you'll end up with a diesel A4 like I did.
Re: Engine troubles
Posted: Wed Jul 09, 2014 5:06 pm
by RS6chris!
Had great service from Teeside over 6 years when it was Colebrook and Burgress
It's now part of Benfield group and standards have slipped.
They rave about that Rob guy who works there now....but all dealings I have lately haven't been the best.
Good luck
Re: Engine troubles
Posted: Wed Jul 09, 2014 7:47 pm
by Chris-RS
Well touch wood, upto now I've had a pretty good service from them. Also bought the RS3 from them and that's been in a few times for warranty/recall work.
Re: Engine troubles
Posted: Mon Aug 04, 2014 6:54 pm
by Andy_S
How are they getting on with it, must be taking some fixing?
It was still up on the lift this afternoon.
Re: Engine troubles
Posted: Mon Aug 04, 2014 7:29 pm
by RS6chris!
Make sure they keep it for a couple of days once engine back in to check for leaks etc?
Re: Engine troubles
Posted: Mon Aug 04, 2014 7:50 pm
by adsgreen
RS6chris! wrote:Make sure they keep it for a couple of days once engine back in to check for leaks etc?
tbh there isn't much where it could leak. it's part of the procedure to check the connections with the engine inplace and running so shouldn't need more than that.
With a car up on a lift with the undertray removed its very easy to spot leaks.
Re: Engine troubles
Posted: Mon Aug 04, 2014 9:00 pm
by R1RS4
RS6chris! wrote:Had great service from Teeside over 6 years when it was Colebrook and Burgress
Good luck
That wouldnt be Rob "Chorley" by any chance the guy who worked at Audi Camberley...great guy just wondered where he went?
Re: Engine troubles
Posted: Mon Aug 04, 2014 9:33 pm
by RS6chris!
Yes it is
Very knowledgable about my RS6 when it was in.
