Tyre pressure monitor
Posted: Thu Apr 24, 2014 10:11 pm
by Moonmonkey831
Hi all,
I was driving earlier this week when all of a sudden the tyre pressure alarm kicked in and said I should immediately check all 4 tyres.
As well as shitting me up I pulled over to visually check and then went to the next garage to check. All 4 tyres were fine.
The only thing I can relate it to was the road surface suddenly changed from nice black Tarmac to those horrible concrete roads, that's when the alarm kicked in.
Anyone else faced this or do you reckon it's a one off?
A
Re: Tyre pressure monitor
Posted: Thu Apr 24, 2014 11:42 pm
by smudge
I've had the warning come on, and pressures were down, but nothing to write home about. It did seem a little dramatic to say the least. I was parked up on the driveway when mine went off, so I feared I had a puncture. Maybe its just all or nothing.
Posted: Sat Nov 22, 2014 9:20 am
by tiger78
Mine came on last night, pulled over to check pressures but couldn't find anything manual or door - what's everyone's running pressures?
Posted: Sat Nov 22, 2014 1:03 pm
by carsarecool
I swapped rears to the front and vice versa which triggered my TPMS. I run mine at what Audi say on the Sticker.
Posted: Sat Nov 22, 2014 5:08 pm
by tiger78
Where is the Sticker. I have checked my door and fuel cap but nothing
Posted: Sat Nov 22, 2014 6:24 pm
by Snotsicle
It is on the edge of the driver's door (i.e. the door itself, not stuck in the door jamb like they used to be).
Took me a while to find it the other day.
Posted: Sat Nov 22, 2014 7:13 pm
by carsarecool
Posted: Sun Nov 23, 2014 8:18 am
by tiger78
Posted: Sun Nov 23, 2014 9:13 am
by carsarecool
M + S = mud and snow
Posted: Sun Nov 23, 2014 4:35 pm
by Eli
Interesting, the label on mine puts the 20in summer wheels at the same pressure as the winters shown in the picture (rather than the same as the 19in).
I assume it is something to do with equipment level?
Posted: Sun Nov 23, 2014 6:27 pm
by carsarecool
I have sport pack and 20s - MY14 car.
Posted: Sun Nov 23, 2014 9:58 pm
by Eli
carsarecool wrote:I have sport pack and 20s - MY14 car.
Mines a MY13 and with sports and tech packs
Posted: Thu Feb 11, 2016 2:55 am
by jukka
I suppose you guys already figured this one out, but decline in temperature (outside) can trigger the warning. If you set the pressure values at say +25 degrees, and then the temperature drops to say +10 degrees, this could be the cause. Also, tires will naturally deflate slightly over time, maybe 1 psi over a month or 2...
Posted: Wed Feb 17, 2016 4:02 pm
by Graeme4130
I've had mine go off randomly, and tyres seem ok, and then got a full flat puncture and it didn't go off.
IIRC, the system works on wheel speed sensors and then determines that an increase in wheel speed (from radius decreasing if the tyre's flat) could be a flat tyre, rather than the individual tyre pressure sensors that other brands use
Posted: Thu Feb 18, 2016 3:19 pm
by smudge
I would agree. I was having a spirited run up the M1 last year when I noticed the catseye sounding very hard when I changed lane. No warning came up until I slowed down on the hard shoulder..... Full flat front offside - beautiful
