B8 RS4 spec Q - DRC
Posted: Tue Oct 15, 2013 5:42 pm
by the911 sc
Hi All,
I have my build week (45) for my RS4.
I havent specc'd sports pack as I am not that fussed on the 20's, sports exhaust or especially the dynamic steering.
Can anyone confirm what the standard setup is as I believe it has the 4 settings (inc user) for throttle, shift points and maybe suspension?
This is what the brochure states as std spec..
Audi drive select – changes your car’s
handling and responses at the touch
of a button to suit the way you want
to drive. Enables the driver to alter the
throttle response, the shift point of
the automatic transmission, exhaust
flap control and the power steering
feel between the three pre-set modes:
comfort, dynamic and auto or
individual mode
Electromechanical power steering
quattro® permanent all-wheel-drive with
Sports differential
RS 4 Sports suspension
with damper control
Tyre Mobility System
Re: B8 RS4 spec Q - DRC
Posted: Tue Oct 15, 2013 6:04 pm
by doodlebug
Dynamic, comfort and auto are the three settings.
Posted: Mon Oct 21, 2013 2:50 am
by nwk00
Depending on what you specced, in the drive select screen you might not get to choose certain stuff. From Chris Haris YouTube, there are 5 different options. I believe his is fully specced.
Engine/gearbox, suspension control, dynamic steering, sports differential, adaptive cruise control. If you didn't buy the option, the option is not available at all on screen.
I think engine/gearbox is standard option. I am guessing the rest are probably optional in some regions. Sports suspension with DRC is for suspension control. I saw a local car without this feature and therefore has 3 options only on the drive select screen(also without adaptive cruise control option). I suspect if you don't select dynamic steering you might even get to see this on the drive selection screen. Making the things you can play with even less. Some people might like the simplicity.
I am not sure if sports differential is optional in some regions. It is inclusive in the spec in my country. I do seem to recall seeing that it is option in a brochure in another country.
Posted: Mon Oct 21, 2013 5:09 am
by nwk00
Chris Haris test car
Local car with sports suspension and DRC.
Local car without sports suspension and DRC.
I can only guess if you don't have the Dynamic steering and sports differential options, it will be only one option for Engine/gearbox(with it's 3 settings)
Posted: Mon Oct 21, 2013 2:06 pm
by eightfoot
nwk00 wrote:
Chris Haris test car.
mines the same as this (first pic) but has dynamic exhaust sound at the bottom instead,i have sports pack not tech pack
Posted: Mon Oct 21, 2013 2:09 pm
by eightfoot
doodlebug wrote:Dynamic, comfort and auto are the three settings.
and individual with sport pack
Posted: Mon Oct 21, 2013 2:15 pm
by doodlebug
Yes, those is the three settings as overall defaults, or within each item as individual. The latter you get regardless of sports pack.
Posted: Mon Oct 21, 2013 3:52 pm
by nwk00
You mean to say there is an option for dynamic exhaust sound? Did you get the sports exhaust? What are the settings available under the dynamic exhaust sound option?
Posted: Mon Oct 28, 2013 1:50 pm
by the911 sc
Thanks all - I dont have the sport pack specced or adaptive cruise so guess will have the standard (which i am ok with). I wanted to avoid the steering as recommended by harrismonkey himself!
Posted: Mon Oct 28, 2013 6:32 pm
by Graeme4130
Mine shows as dynamic engine, which puts shifts into S and opens exhaust valves
Incidentally, you can just shift it from S to D bad you grf comfortable shifts and the louder exhaust remains
