Page 1 of 2
New RS4 paddles
Posted: Fri Aug 02, 2013 2:32 pm
by Brooner
Got these today
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 2:33 pm
by Brooner
So fist bit align the steering wheel at 90 deg to expose the access hole for the air bag catch there is a cut out in the steering column to access the lower catch.
Then remove the battery terminals so the air bag does not go off
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 2:34 pm
by Brooner
Then you will need a small screw driver to push the catch towards the centre of the steering wheel, while pulling the air bag and you will feel the air bag move, repeat for the other side.
There is no need to remove the airbag.
Re: New RS4 paddles
by Brooner
Then tease the black trim out of the steering wheel I did this side at a time
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 2:35 pm
by Brooner
Unclip the connector and the I star head screw holding it in place
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 2:36 pm
by Brooner
Then gently pull out the old paddle and insert the new one tighten the screw re connect the wire connector and repeat the other side.
Once both sides are done, double check the black trim around the steering wheel is fitted correctly, and all the wires are were they should be, then align the airbag and push back in you will feel the clips catch.
Then re connect the battery terminals and your done.
Took me an hour and I’m a mechanical <beep>.
much better for 10-2 hand psition and cost £201 from Audi
ok not as smart as the R8 paddles but OEM thats what i wanted
and the sharp eyed out there will notice the air bag is not fitted corrctly i did take it off and re fit
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 2:41 pm
by 535dboy
Are they much bigger or is it just the better quality than crap plastic you have gone for?
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 3:11 pm
by Brooner
They are bigger and are the standard fit on the newer RS4
Crap plastic????
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 3:46 pm
by Graeme4130
They look better
Are they standard fit for 2014MY rs4 ?
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 3:49 pm
by Brooner
Yep standard on the currant RS4 not sure when theycchange them but must have been the last few months
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 5:49 pm
by 535dboy
Brooner wrote:They are bigger and are the standard fit on the newer RS4
Crap plastic????
Sorry I meant the originals I have and you had
Feel cheap for £65k car
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 6:52 pm
by Graeme4130
535dboy wrote:Brooner wrote:They are bigger and are the standard fit on the newer RS4
Crap plastic????
The newer ones do look a lot better, but I can't say I've ever noticed my current ones being too small
Like they say, bigger is always better though
Not that I can bloody drive it at the moment anyway as I broke a few ribs and knocked myself out on my bike Wednesday and am currently laid up
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 9:07 pm
by doodlebug
Ouch! Out for long?
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 9:11 pm
by Graeme4130
Hopefully not too long as off to morzine for a week downhilling on the 18th
Now on high calcium/protein diet to try and get fixed quick
Re: New RS4 paddles
Posted: Fri Aug 02, 2013 9:14 pm
by doodlebug
No bull semen I hope!
