Hi guys,
can anyone advise on the tire cracking problem I'm facing with my RS4 B8? Despite all the care I have with my tires, I can't seem to stop it from cracking all tires in less than a year of light use, and half of the rubber is still to wear.
At least, the last 4 sets of tires were gone this way and I find it quite frustrating since I'm not abusing the car at all.
I do notice a lot of resistance when tight cornering at low speed and I do believe these 2 issues might be connected. I did read other comments accepting the tight cornering issue as normal in Audis but I find it not normal on my car.
Could there be a wrong setup of suspension, wheel alignment, wrong tire pressure (using 42 PSI front / 39 PSI back) or diff issue?
This is turning my experience with this car so bad that I'm already considering a potential sale.
Any thoughts welcome.
Best regards
Tire cracking
Re: Tire cracking
FYI - https://www.blackcircles.com/ have 15% off today, could be wrong tyre pressure.
Re: Tire cracking
Is the car running standard suspension?
What brand are the tyres?
RS4 64 plate Prism Silver with just enough toys...
Gone but not forgotten
2014 C63
2010 C63
Clio Cup
E60 M5
E46 M3 CSL
E46 M3
E36 M3
E30 M3
Mitsubishi Evo 8 FQ300
2014 C63
2010 C63
Clio Cup
E60 M5
E46 M3 CSL
E46 M3
E36 M3
E30 M3
Re: Tire cracking
Suspension is all standard and the tires I'm using are the Michelin Pilot Super Sports.
What are the tire pressures you guys are using? As per the manual, I've been using 42 PSI (front) and 39 PSI (rear).
Re: Tire cracking
That's split on the inside edge of the tread, are they all like that? And what date code are they?
Also where are you, what's the weather/climate? (Tire suggests USA or Canada ....)
Re: Tire cracking
I live in Dubai, UAE (yes, temperatures are often quite extreme but i haven’t seen this happening on any other cars I know. This usually happens in my front tires, not the rear ones, but pretty much every set of tires goes like this… i may have never used all the rubber of any of my front tires.
The ones that i just changed were a year old, manufactured maximum 2 years ago.
Users browsing this forum: No registered users and 146 guests
