My RS4 sits wonky??
My RS4 sits wonky??
Have owned the car for a couple of months now and to be honest I have never looked at the arch to wheel gap in much detail but I have noticed that the passenger side sits probably 20mm higher than the drivers side. From googling I have come up with the answer that when the car is started and driven it levels itself up etc?? Is this the case??? If the reason is bad then please don't tell me, click the back tab on your browser and say no more about the situation.........
Re: My RS4 sits wonky??
Noticed that about mine but it doesn’t sit on a level surface at my house. Will check in the company car park today
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Following, as I sometimes noticed this about mine...but driveway is sloping too and put it down the DRC suspension and due to it not sitting on a level drive. Only had it about 10 weeks, but noticed it once or twice...
Current: RS4 B8 Panther Black
Audi E-tron (daily driver)
Previous:
BMW X3 330 MSport, Carbon Black
Porsche 911 997 C2S Manual, Basalt Black
BMW 330d Manual MSport Convertible
Previous:
Hard to measure but my car is slightly up at the offside rear. Maybe by 1 cm? Front nearside/offside seems level
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
There is a huge thread on uneven ride height - it was brought up in connection with DRC troubles
Current:
- Audi B8 RS4 - Panther Black
Previous:
Previous:
Shockerboy
- Trader (Expired)
Before panic sets in , open the drivers window push the top of the door / roof vigerously side to side and slowly come to a rest ( on an even FLAT surface ) , check gaps from centre of Wheel only, to top of the arch ( apex ) . anything more than 10 mm could be an issue , the agents would say normal up to 12 mm . remember shocks are there to resist movement so generally all cars sit lower on drivers side after driver has got out of the car the shock is trying to hold that side from moving back up . It will move up to apoint but 9 times from 10 it will hold lower .
- innercry666
I hate to give the stock Audi answer but, "they all do that sir!". Everyone I have seen seems to sit lower at the rear right. I had the front shocks replaced on mine and it did exactly the same before and after. Before selling my next step was to fit adjustable KW springs to see if it could be dialled out.
As they all do it, it may well be a characteristic of the DRC system itself. It never seemed to cause an issue.
RS6 PE - Current
RS4 (B8.5) 2015 - Sold
A4 3.0 TDI Quattro BE Avant - Gone
Focus ST170 - Garaged
All standard cars sit uneven 10mm is nothing to worry about as the weight of your car varies above each wheel. If you want all heights equal you need to fit coilovers and have your car professionally corner weighted.
MK2Golf24v
Corner weighted is a process term and as part of the process each corner of the cars suspension height is adjusted so that the they are equal ie fronts equal and rears equal eg my E36 M3 I had done recently, refer to Yellow speed heights:
With the earlier issues surrounding knocking or leaking front shockers with DRC, some owners were reporting that when the new shockers had been fitted, the ride height on the side of the replacement shocker was different to the opposite side. You wouldn't have thought it would alter the ride height side to side if a pair had been replaced; maybe it was if just one corner had been replaced.
Your local Audi dealer should be able to go into your cars history and tell you if any warranty work with the suspension has been done on the car and exactly what was replaced.
MK2Golf24v
Mine has always had a slight difference left to right at the rear, usually rear pas side higher. Ranges from 5-25mm depending how its parked. Some time its even....
Just put KW springs on it, have kept the lowering the same each side, so still have the slight mis-match. just had the DRC pressures checked at Audi, 20bar both systems, so all good there.
I suspect its the relatively thin ARB not transferring a lot of load across the axle when static, and letting the DRC do the work while the car is in motion.
Thread resurrection!
Just had a rear DRC pipe replaced and system refilled and re-pressurised.
Noticed today that when sat the rear drivers side is sat lower, prob about 10mm from wheel, others are 20mm perhaps. Not measured.
I am guessing this is "they all do that" territory? Any one got a link to the longer thread?
- Rugslasher
- 1st Gear
Mine did the same ........ until I ripped the DRC offspoonz wrote: ↑Wed Mar 31, 2021 5:23 pmThread resurrection!
Phew. It looks fairly <beep>, but given its had the best part of £3k spent on DRC in the last 12 months, Im glad its not another pending visit from Mr B.Bills.
Users browsing this forum: No registered users and 134 guests
