Tyre pressures! So sensitive to changes ...
4.2 V8 32v FSI - 444 bhp
MadMark
Post by MadMark » Tue Mar 02, 2021 12:06 am
Isn't the car susceptible to tyre pressures?
When I first got mine, the drive on the way home felt slightly odd under heavy braking and perhaps not as precise as I was expecting as it kept pitching left. I think the previous owner hadn't used it in a while and may not have checked them as he was selling the car, plus the rear right valve was wound too tight to take a reading initially (soon loosened off a quarter turn).
They read as:
Front L - 33.5
Front R - 34.0
Rear L - 35.0
Rear R - 38.0
Now all changed to 38F and 35R - it's like a different car! :)
RS4 B8 - Sepang Blue, Black Leather, Aluminium Pack, 20" V-Spokes.
CusterDome
Re: Tyre pressures! So sensitive to changes ...
Post by CusterDome » Tue Mar 02, 2021 11:20 am
I'm surprised your tyre pressure sensor didn't light up. Did you get the option on your dash to reset it when you altered the pressures?
G30001
Post by G30001 » Tue Mar 02, 2021 11:41 am
Low profile tyres.
When you nail tyre pressures the car is so different.
this time of year is worse as the temps are all over the place as like Autum, could be previous owner had done the tyres in the depths of Winter
2013 B8 RS4 - Reflex Silver Black Pack probably the 2nd lowest mileage in County
2014 B8 RS4 - Daytona Grey bag of nails with Silver Styling gone
Rusty Racer
Post by Rusty Racer » Tue Mar 02, 2021 1:36 pm
Agreed, with such a heavy lump up front it’s a good idea to check regularly (of course we all do anyway!)
If you kept resetting the TP warning as the pressures vary it will defeat the object of having it - no great science behind it the ESP looks for crabbing iirc
2018 RS4 B9 Carbon Edition
2014 RS4 B8
MadMark
Post by MadMark » Tue Mar 02, 2021 1:44 pm
I was surprised it didn't set off the sensor - but my run home was mostly motorway, so the pressures would have been up anyway. Testing them cold the following day was deliberate and I reset the pressure sensor reset straight away by delving into the menus!
I'm pretty good with checking mine at least every month if not sooner.
CusterDome
Post by CusterDome » Tue Mar 02, 2021 1:45 pm
I've never had to reset my TP warnings except when there's been an obvious change in pressure, - puncture, new tyre etc. I'd assume that it's not that sensitive to put up a warning with normal day to day changes, the 4psi change that MM made must be within its trigger range.
MadMark
Post by MadMark » Tue Mar 02, 2021 4:08 pm
Unlike the pressure sensors in the BMW M and Porsche ranges, these don't measure real time pressure and temperature, which is really useful in the real world. These are much more basic and I understand only trigger with something over a 25% pressure drop on one or more tyres (approx. 9psi). However, if all 4 tyres are equally low, it doesn't register the pressure drop!
Rusty Racer
Post by Rusty Racer » Thu Mar 04, 2021 1:01 pm
Wheels use a standard valve and it’s all done through the ESP I believe
2014 RS4 B8
Users browsing this forum: No registered users and 132 guests
