Dash warning message- sport diff malfunction
4.2 V8 32v FSI - 444 bhp
Scammo1
Post by Scammo1 » Tue Dec 22, 2020 3:42 pm
Hi, got the above amber warning light pop up on the dash this morning when switching the car on.
Has anyone experienced this before or know more on what it could relate to please?
Car is driving fine with no noises or any sign of a fault. Only 30k miles and hasn’t recently been driving vigourously.
Booked in with Audi in the new year. They said it should be fine to drive normally just don’t use sport drive select.
I fear a big bill but luckily it’s under warranty still.
Any help/advice greatly appreciated!!
Rusty Racer
Re: Dash warning message- sport diff malfunction
Post by Rusty Racer » Thu Dec 24, 2020 11:36 am
Hard to say without a scan but a low battery seems to be causing issues with other owners atm.
Don’t think there are many problems with the actual diff 👍
2018 RS4 B9 Carbon Edition
2014 RS4 B8
Scammo1
Post by Scammo1 » Thu Dec 24, 2020 2:45 pm
Thanks. Been researching and hope it is just a software issue and simple fix.
Annoying going to have to wait until new year to resolve.
Scammo1
Post by Scammo1 » Fri Jan 08, 2021 4:26 pm
Thought I’d update this thread with the outcome of the error code I got in case anyone searches in the future.
Basically it turned out to be the rear diff oil sensor sending a sporadical signal to the car. Fix was to change its actuator and replace the rear diff/haldex oil.
Luckily under warranty so no cost, but Audi confirmed it would have been two hours labour plus the part and 2l of oil so I would guess about £600 if someone was paying.
Now I just need to find opportunities to really test the sports diff 8)
Rusty Racer
Post by Rusty Racer » Fri Jan 08, 2021 5:29 pm
Glad you got it fixed! Even better when it’s a freebie 👍
2014 RS4 B8
JJSscooby
Post by JJSscooby » Fri Jan 15, 2021 6:45 pm
Hi all, just adding to this thread, I get this malfunction when i hit a bump in the road at speed, any ideas?
When the car starts i don't have any error messages?
Scammo1
Post by Scammo1 » Fri Jan 15, 2021 9:15 pm
Mine came on once, then didn’t when I switched it on again but did and stayed after that.
Audi said it’s very rare for the malfunction light to actually be caused by the diff itself and is usually due to either an issue with the oil sensor (like mine) or insufficient diff oil- which if ignored could lead to a very expensive diff fault.
I’d recommend getting the ECU read for fault codes at Audi or a specialist as each time this occurred it would have been logged in your ECU. This will tell you exactly what it is.
JJSscooby
Post by JJSscooby » Sun Jan 17, 2021 3:03 pm
ok thanks for the input
Melk63
Post by Melk63 » Fri Aug 27, 2021 5:31 pm
Hi, resurrecting this thread looking for some help and advice to locate a specialist RS differential garage.
I have had the “Sport Differential malfunction” warning light permanently on my 2014 RS4 dash for a few weeks and have already spent around £1000 with Audi main dealer and an Audi specialist to find the cause. Tests by both have confirmed the diff itself to be mechanically sound, the ECU to function correctly and the two communicating properly. The car drives perfectly with no noticeable diff problems. The problem may the electronics inside the diff. Short of a very expensive new diff, none has come up with a solution.
I am now looking for a third opinion from an RS Diff specialist. Can anyone please recommend one?
One other question: Would the car fail its MOT with this warning light on dash?
Thanks,
Mel.
beastvan
Post by beastvan » Thu Jun 15, 2023 10:39 pm
I am having an issue with my brand new RS6 :x I am hoping to use your experience to figure out what is going wrong... viewtopic.php?f=138&t=143864
Current car: Audi RS6 C8 '23 (EU spec)
Theboyg
Post by Theboyg » Sat Jun 17, 2023 8:50 am
Thanks,
Mel.
You may have already looked at this, but this was the first message I had one mine, it was intermittent at first and then turned into other messages (TPMS etc.) which when I researched it I thought it might be battery related as someone else mentioned earlier in the thread. I replaced the battery, but it wasn’t that, turned out it was an intermittent fault on a rear wheel speed sensor, had it replaced and all OK, thread here - viewtopic.php?f=61&t=143642&sid=779baaf ... b609831e8d
Users browsing this forum: No registered users and 92 guests
