Ceramics B9 400mm retrofit project
Re: Ceramics B9 400mm retrofit project
Good work Sam.
My calculations suggest a 5.2mm spacer needed behind the disc. So a ordinary 5mm should allow you to mock up.
Can you use the b8 carriers? It’s a little tricky as I suspect the calipers are Alcon not Brembo but they might be the same bolt pattern. You can then adapt out with a spacer from 365mm to 400mm. Maybe better would be the use of a carrier from an S7/S6 4G as same size disc and very similar Alcon caliper (If not same?).
Or try Epytec.de for a fully custom carrier.?
RS4 B8 Porsche Riviera Blue
- Surrey Sam
@ Bam - Cheers, hope it'll be worth the effort.
Fivetones - The B9 ceramic callipers are Brembo items and do have a different bolt pattern to the B8 steel Brembos unfortunately. They're huge, and I believe the same ones as fitted on current RS6, RS7 and S6/7 ceramic equipped cars. It's just the disc size/offsets’ and calliper carrier changes between models. Akebono now make the steel callipers for the B9 RS4.
Thanks for the Epytec tip, another member has pointed me in their direction too.
Users browsing this forum: No registered users and 462 guests
