Parking system failure/screen greyed out
Hi Guys, parking the car last night the parking switch started flashing and a long beep, no rear camera or lines and in MMI the system is greyed out, any ideas? Car is under warranty but hate the dealers touching it
- Surrey Sam
Re: Parking system failure/screen greyed out
Unless you have VCDS software and a cable, there is no way to tell what is up with it. There will be a fault code logged, so it's just a case of reading that and going from there I'm afraid. Most likely a component failure such as a sensor, the control unit then disables the whole system.
Good luck with it and be sure to report back what they do to fix the problem.
Thanks - will do
chandler99
I had exactly the same issue fixed recently.
The problem was due to a faulty front sensor that later failed. Once replaced.. All sorted
Yep you need to reset MMI by pressing and holding power button....worked on an X5 we hadSilver7 wrote:Hi Guys, parking the car last night the parking switch started flashing and a long beep, no rear camera or lines and in MMI the system is greyed out, any ideas? Car is under warranty but hate the dealers touching it
Ok wil try that thank you
chandler99
Don't think that will work on an RS4. Book it in to Audi and make sure they give you an S4 for loan
Astonished
To reset MMI press and hold simultaneously:
Menu
Centre Button
Top Right Button
But this may only do the same as if turning off car and leaving for something like 15 mins.
Dealer's really helpful techo mechanic told me this after applying it when my phone/MMI froze.
It works
Menu
Centre Button
Top Right Button
It works
Reset does a hard reset which is more than turning the car off. Also, Carista will give you fault codes at a far cheaper cost of VCDS, if you want to fix it and make changes then VCDS will probably be required.
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
Thanks for the advice - car went to Audi and one rear parking sensors replaced and systems reconfigured. Odd that a single sensor takes out the rear camera!
chandler99
its for safety.. if the system just worked (bar the faulty sensor) and you hit something, i guess Audi think you'd be taking aim at them for the repair.
Ok thanks - you would have thought an error message could be put up and some incessant beeping to cover the liability. Anyway onwards and upwards !
Geoffdunk - just got Carista to change some things and can’t find this one on the app, can you point me in the right direction for this and any other good suggestions?
Current:
- Audi B8 RS4 - Panther Black
Previous:
Previous:
Users browsing this forum: CusterDome, Google Adsense [Bot] and 45 guests
