RS4 B8 MMI Map Update
Re: RS4 B8 MMI Map Update
£268 for the summer 16 update
Just make sure that also include's the firmwar update as the map update will be no use without the correct firmware. I had this in my A7 about 6 months ago. I got the update and it still showed old map version on MMI and also i checked the places i would expect to be on the update and they were missing. In the end i had a battle with the dealer and they updated the firmware and then finally it all worked correctly. You need to do both.DeanoC wrote:£268 for the summer 16 update
Sepang Blue RS4
Top man, thanks for that.AFN380 wrote:Just make sure that also include's the firmwar update as the map update will be no use without the correct firmware. I had this in my A7 about 6 months ago. I got the update and it still showed old map version on MMI and also i checked the places i would expect to be on the update and they were missing. In the end i had a battle with the dealer and they updated the firmware and then finally it all worked correctly. You need to do both.DeanoC wrote:£268 for the summer 16 update
Users browsing this forum: No registered users and 198 guests
