Steering, struggling to find a setting I like
Had the 2014 B8 RS4 for about 3 weeks now. I'm yet to find a steering setting that I like. It just feels heavy all the time, especially at lower speeds (30mph). Is it me or anybody else had the same issues?
2014 Audi RS4 Avant Viper Green "The Hulk" ● BMC Filters ● 034 Motorsport gearbox mount ●
2014 Audi S1 Mythos Black "Fuzz" ● Revo Induction ● BMC Filter ●
1995 Land Rover Discovery 300TDI "Gunbus" ● Under Restoration to original OEM Condition ●
- Surrey Sam
Re: Steering, struggling to find a setting I like
Do you know what steering system you have?
Sorry, should of added that. Dynamic Steering as part of the Sports Package so car has DRC as well
- Surrey Sam
No problem. Just thought I'd check, as some cars don't have the adaptive steering and that could feel different.
I have the same steering rack as you and in ADS (Audi Driver Select) Dynamic mode, I do find the steering too heavy at low speed. However the Dynamic steering setting at speeds above 50ish is good, as it's less fidgety.
So, I've found that having the ADS in Individual mode and then utilising the Auto setting for steering works really well. Around town and for parking situations you get the light Comfort steering, then when you want to press on, it increases the resistance to Dynamic levels for when you’re travelling at speed. This is a great all round setting for the steering (good for suspension too) and have been really impressed by it - as I'm always sceptical of anything 'Auto' but Audi have clearly put some development time into this.
Does your steering feel any heavier going between the Comfort and Dynamic settings?
I'm always in individual and have everything in dynamic apart from the suspension.
I used to have steering in comfort or auto, but changed to dynamic. Heavy at first, but it suits me and the car, I feel, better. Maybe it's the contrast with the wife's discovery which has featherweight steering.
I'm using comfort and have the dynamic steering and find it can be heavy in certain circumstances but prefer it over dynamic. On the motorway if there is a long corner and I'm just cruising I would like it to be lighter say.
'15 - RS4 (B8) - Nogaro
These cars are alignment sensitive, they can be quite fidgety requiring regular inputs to correct the steering.
A good test is a flat straight road, pull towards the centre line and take both hands of the wheel. It should wander towards the gutter in around 7 seconds. Mine was doing this in 3 seconds, I'd definetly recommend a good quality alignment setup even on the standard DRC.
I have mine in comfort all the time and have plenty of feedback and weight. Although when Marc1 who has a B7 drives mine he prefers dynamic for the steering.
2016 BMW F80 M3
2014 B8 RS4 - Milltek Non-Res - KW V2's with DRC delete - Setup by Centre Gravity. - Sold
2013 Q5 2.0 Tdi
1997 BMW E36 328i track car
2013 Q5 2.0 Tdi
- Shinobi675
- 5th Gear
This is good stuff! The auto always confuses me. I couldn't tell the difference between comfort and auto. I'm now thinking that I Was probably comparing it only at low speeds! Will give this a try.
I do wonder if it's possible to tune the steering. At the end of the day I think it's just force feedback. So should be able to change this... What to! Not sure yet. But I'd like to stop needing to over correct when pushing on. Just feels a little delayed.
Auto will tend to be in comfort by default. However, if you start driving more spiritedly then you'll notice it move towards dynamic, being a bit more aggressive on the gear changes, feeling stiffer (suspension and steering) and particularly when the exhaust note changes! It's as if the car says "oh, hello, you want to play?"
I admit I tend to leave it in auto much of the time, perhaps flicking to sport with the gear stick if I'm going to play or just letting it work it out for itself. I really ought to try the manual more often, other then dropping a cog or two to give more engine braking on hills, but I've got a bit lazy and too be honest I still prefer a stick shift rather than flappy paddles.
- Revolution
- Trader (Expired)
I drove in auto for the first year and it always annoyed me so I switched
To individual with all in auto apart from steering that is set to comfort.
Works a treat.
Works a treat.
http://www.revolution247.com
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
Sold but never forgotten:
2014 RS4 Sepang Blue
2015 VW Golf-R
2012 RS3 Sepang Blue
RS4 B7 Avant Daytona
2002 Renault Avantime V6
2006 2-door Impreza STi
2009 TT TDi Quattro
10 Subaru's inc 22B type UK
Renault Clio V6 MK2
Civic Type-R's Mk1, 2 and 3
205 GTi 1.6 & 1.9 Gutmann
2016 RS3
2018 VW Tiguan
2010 Smart fourtwo
2015 VW Golf-R
2009 TT TDi Quattro
Renault Clio V6 MK2
The RS3 guys have adjusted the weight of the steering using VCDS. It is at 100% by default and they have lowered it to 60% to make it heavier. Not sure if you can increase it to over 100 to make it lighter though.
I assume you can do the same for the RS4. They needed the security code to do it too.
I use individual all the time and pick my settings, this is the ideal choice for me. I can't remember them all and the wording but I know the steering is Auto so at low speeds it lighter and and at higher speeds its heavier and you don;t wander all over the road. The lock to lock changes too as wheel as the weight.
My INDUVIDUAL settings are:
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
Users browsing this forum: No registered users and 228 guests
