Disabling boot release button on remote fob
4.2 V8 32v FSI - 444 bhp
Reevesy
Post by Reevesy » Sat Feb 06, 2016 11:25 pm
Is there any way of disabling the boot release button on the remote fob?
geoffdunk
Re: Disabling boot release button on remote fob
Post by geoffdunk » Tue Feb 09, 2016 11:53 pm
Yes, it can be disabled by using the Carista app, but why?
MY2015 Audi RS4 Avant quattro, Panther Black Crystal, Black leather, Black inlays, 20" V-Spoke wheels
geoffdunk
Post by geoffdunk » Tue Feb 09, 2016 11:56 pm
check here for details of what can be done.
http://www.caristaapp.com/customization ... a4_2013_uk
HPsauce
Post by HPsauce » Wed Feb 10, 2016 12:02 am
That just looks like the normal stuff you can turn on and off with VCDS.
Not sure on the specifics of a B8 re the boot/remote though.
Post by MikeFish » Wed Feb 10, 2016 12:07 am
HPsauce wrote:That just looks like the normal stuff you can turn on and off with VCDS.
Yes, it's just another way of accessing the car's built in options. VCDS does it via a laptop and USB cable (typically), whereas as this app does it via your phone / tablet and a £3 bluetooth OBD adapter. Much cheaper and (seemingly) easier way of doing it, but probably not all options available. I've never used it but I intend on giving it a go with the new car (doesn't list the B7 as a supported vehicle).
mikeyw
Post by mikeyw » Mon Feb 15, 2016 12:13 am
geoffdunk wrote:Yes, it can be disabled by using the Carista app, but why?
Parked mine in Cheltenham about 3 weeks ago, on a friends drive while we had lunch with them. Keys in my pocket, nothing unusual. Came out a few hours later to find the boot wide open.....
Can only assume something in my pocket pressed the boot open, but I'll certainly be looking to disable this function !!! I can see why you might!
Snotsicle
Post by Snotsicle » Mon Feb 15, 2016 7:59 am
I wonder if the boot release switch in the driver's door pocket is disabled when the car is locked. If not, perhaps it is susceptible to either an electrical fault or someone forcing a bit of wire down the side of the door?
Current: Daytona Grey '14 RS4 Avant +most options
Previous Audis:
Phantom Black '07 B7 S4 Avant Tip
Akoya Silver '03 B6 A4 Avant 3.0 Quattro Tip
Ming Blue '99 B5 A4 Avant 2.8 Quattro Tip
Laser Red '97 8L A3 3dr 1.8T
Assorted junk too embarrassing to list
Tweaky
Post by Tweaky » Mon Feb 15, 2016 10:48 pm
I have also come out in the morning on three occasions to find my car in the drive with the boot wide open. I would love to disable the key fob switch also if you find a way of doing it.
MY18 RS4 Carbon edition in Nardo
Post by MikeFish » Tue Feb 16, 2016 1:59 am
These are part of the instructions on how to make the boot close with the remote key fob for the C7:
MikeFish wrote:
Check that both tap and touch are not activated at the same time:
6D – Trunk electronics
Security access – 16 = 12345
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid opening button in remote key-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid opening button in remote key-Touch function for closing) from active to not active
Address 6D:4G9 959 107 A recoded (ADP-(4)-Activation using rear lid remote unlocking switch-Tap function for closing) from not active to active
Address 6D:4G9 959 107 A recoded (ADP-(3)-Activation using rear lid remote unlocking switch-Touch function for closing) from active to not active
This will result:
remote opening – long press - touch
remote closing – short press - tap
door closing – short press – tap
Touch = long press is set for opening to prevent accidentally opening the hatch.
There is probably a similar set of codes for the B8. If so, look for the 2 commands that say:
Activation using rear lid opening button in remote key-Tap function for opening and
Activation using rear lid opening button in remote key-Touch function for opening
And set them both to not active.
All of this is with VCDS of course. It may be easier to use the Carista app. I tried it the other day with my £3 bluetooth dongle and it wasn't compatible. And to change any actual settings you need to upgrade to the $20 version.
Reevesy
Post by Reevesy » Tue Feb 16, 2016 1:31 pm
Exactly this! Il have to ask audi when it's in for service.
Post by bam_bam » Tue Feb 16, 2016 3:38 pm
While you're at it disable the roll windows down when holding the unlock button. I hated coming outside to the car with all windows down.
Post by chunky79 » Wed Feb 17, 2016 7:22 am
bam_bam wrote:While you're at it disable the roll windows down when holding the unlock button. I hated coming outside to the car with all windows down.
That had nothing to do with the key fob. Your car just hates the smell of you!
Users browsing this forum: No registered users and 229 guests
