R3 front drilled discs....
Posted: Thu May 03, 2012 4:48 pm
by n5tews
All
The holes in the front discs are now completely blocked and the local stealer seems to think they can pressure wash them out. This has happened over the last six months gradually filling in the holes with some spirited driving sessions
Thought or advice much appreciated. I'm thinking new disc & pads.......
n5tew
Re: R3 front drilled discs....
Posted: Thu May 03, 2012 4:50 pm
by PJC
Any pics?
Posted: Thu May 03, 2012 5:29 pm
by P_G
Just get a hole punch or drill bit out and unclog them. Common B7 RS4 proceedure when using the soft OEM Pagids. If you want less dust and clogging go for EBC yellow stuffs or Ferrodo DS2500's if either are now aavailable for RS3 but I think they should by now.
Posted: Thu May 03, 2012 6:27 pm
by HYFR
my TTRS disc's filled up in less than 1 week
Posted: Thu May 03, 2012 8:01 pm
by Dave_Hedgehog
P_G wrote:Just get a hole punch or drill bit out and unclog them. Common B7 RS4 proceedure when using the soft OEM Pagids. If you want less dust and clogging go for EBC yellow stuffs or Ferrodo DS2500's if either are now aavailable for RS3 but I think they should by now.
yellow stuffs was about before the RS3 as its got the same brakes as the TTRS
Posted: Fri May 04, 2012 1:48 am
by stu
The compacted dust softens up quite a bit after a soak. I tried cotton buds on mine and it worked well - the cotton tip disintegrates almost straight away but the remaining plastic stick is a surprisingly good size/strength for the job.
Posted: Fri May 04, 2012 1:08 pm
by n5tews
Any recommendations where to go for new pads?
Posted: Sat May 05, 2012 11:10 am
by RS6chris!
Used to use a 4mm steel drill bit and cordless drill on my B7 RS4.
Worked a treat...
Tip...have a few 4mm drill bits as you WILL snap one or two!!!
