RS3 Jack
Posted: Sun Sep 08, 2013 4:50 pm
by hammy969
Hello All
I needed to change one of the rear tyre on my RS at the end of last week. Went to jack the car up with the supplied jack. I wasn't able to as it catches on sill. End up having to use another jack to get the wheel off.
Has anybody else come across this issue?
Re: RS3 Jack
Posted: Wed Sep 18, 2013 10:23 pm
by neckarsulm
hammy969 wrote:End up having to use another jack to get the wheel off
Man! The jack is for raising the car, use the brace to get the wheel off
Re: RS3 Jack
Posted: Thu Sep 19, 2013 1:11 pm
by P_G
Thereare specifc jacking points on the car denoted by indented arrow signs on the side skirts where the have recessed sections the boot jack fits into without it cause damaage or slipping off. Otherwise if you look underneath there are 4 rubber mounts on the underside of the car where Audi jack the car in workshop which also conveniently fit on trolley jacks and are far more secure.
Re: RS3 Jack
Posted: Thu Sep 19, 2013 6:31 pm
by hammy969
Pg
Thanks for the reply. I have used the jacking point that you have described. The problem is when the jack gets to the point where it should lift the car it starts to snag on the outside of the skirt. I ended up using the sissor jack from my a4 to remove the wheel.
I noticed the pads under the car and wondered if they were jacking points.
Cheers Ham
