RS5 Oil cooler
Posted: Sun Mar 31, 2019 6:36 pm
by Buller123
Does anyone know what the narrow small oil cooler under the front bumper at the bottom cools?have a leak from the passenger side found a diagram online can see the o ring(number 7)that needs replaced but cannot find a part number. Any help would be appreciated.
Re: RS5 Oil cooler
Posted: Mon Apr 01, 2019 10:27 pm
by morski
Listed as an oil cooler. O ring is available N91044502 Price is £41 !!! etka must fooked up !
Re: RS5 Oil cooler
Posted: Fri Dec 25, 2020 8:31 pm
by hahnmgh63
Yep, engine oil. There is also a standard small VAG Coolant to Oil exchanger bolted to the block right behind the Alternator at the front lower right of the engine. It helps the oil heat faster when cold and then helps keep it cooler when hot.
