RS5 Oil cooler
RS5 Oil cooler
Does anyone know what the narrow small oil cooler under the front bumper at the bottom cools?have a leak from the passenger side found a diagram online can see the o ring(number 7)that needs replaced but cannot find a part number. Any help would be appreciated.
Re: RS5 Oil cooler
Listed as an oil cooler. O ring is available N91044502 Price is £41 !!! etka must fooked up !
A6 BiTdi Avant
Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Retrim
To be done: Lane assist, ACC, Keyless
Re: RS5 Oil cooler
Yep, engine oil. There is also a standard small VAG Coolant to Oil exchanger bolted to the block right behind the Alternator at the front lower right of the engine. It helps the oil heat faster when cold and then helps keep it cooler when hot.
Users browsing this forum: No registered users and 4 guests
