What Brake discs
Posted: Sat Sep 29, 2012 11:23 pm
by marky mark
Needing new discs on the front of the S6 soon,
anyone running these??
are they any good?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:en
cheers in advance
Re: What Brake discs
Posted: Sun Oct 21, 2012 7:47 pm
by marky mark
a word of warning there are 2 types of caliper used on the S6, check the top hat measurement on your old discs first as they did not fit my car.
see notes
If you have the 321mm fronts, you need to be careful when ordering as I believe there are 2 variations of this rotor.
one uses the 4 pad per caliper (Lucas Girling 2 piston) and the other the 2 pad per caliper (ATE single piston). The 4 pad was used
on the S4 and some Allroads and the 2 pad on the C5 sedans (I believe). To make sure, I would suggest to measure the rotor
hat height and order accordingly.
(Assuming you have the 321mm fronts) Look at the ECS Tuning (http://www.ecstuning.com)
