Auto Gearbox Rebuild
Posted: Fri Jan 16, 2009 10:56 am
Hi,
After having my S6 for under 3 months and with only 81k on the clock I noticed that the gearbox would give the odd judder when coming off a roundabout in 3rd gear. The car was going in for an oil change so I though I would get the gearbox oil and filter done at the same time. Parts cost about £146 from Audi. Apparently you only use the proper Audi oil at £10 a litre. Anyway I got this done and all seemed good for a week afterwords, gear changes all smooth and nice, then the judder started again. I re-checked the oil level a few times to make sure it was right. But the juddering got worse. After some research on Audiworld I found out that the 5HP-24A auto box in the S6 is very prone to failure. So to cut a long story short, the car is now in for a gearbox rebuild at a cost of £1600 + vat. Not good at all….. There is lots of info on www.audipages.com about the gearbox. Also it is the clutch hub or basket that has ripped on mine and therefore needs to be completely rebuilt. Has anyone else had any problems with their gearboxes? Also vag-com shows no gearbox codes and no dash lights etc… Just thought I would share my horror story.
