S6 propshaft - refurb-shers?
Posted: Wed Jan 09, 2013 12:54 pm
Hi, I recently bought an S6 from a mate, which had a suspected gearbox problem (that I knew about!) - slight and occasional clonking when pulling away, occasional vibration from under the car. The local independent guy I took the car to for a checkover has ID'd the propshaft support bearing as being the culprit.
This bearing is bonded to the propshaft via a rubber bush. Does anyone have any experience of refurbishing propshafts like this? There are dozens of companies doing work like this, I just wondered if anyone knows a company that they would recommend.
The standard Audi part is £1100 plus fitting - I'm sure the bearing would only be a couple of hundred, plus refurbishing charge.
I'm at Camberley so nearby geographical location would be helpful but shouldn't be an issue.
Thanks - for any guidance at all on this!
