Page 1 of 2
2 days .... 2 problems
Posted: Thu Jan 19, 2012 4:45 pm
by HYFR
early days i know but
1. the MPG seems to be worse in the S-Tronic vs. manual
i mean motorway cruising in 7th gear at 85 / 55 (roadworks) in the manual it would have got 30-32 mpg easy ... the S-tronic struggled to get 27mpg
ok ok ok, only 250 miles on the clock, so lets see how it goes
2. in M mode (stick over the left) the car changes up by itself from 3rd to 4th !!
what the fcuk is that all about ... its meant to be manual ... the TTRS S-Tronic didnt do that, it just hit the limiter like a proper manual
had to try it a couple of times in case id mistakenly hit the paddle
not happy about that ! anyone else found this ?
Re: 2 days .... 2 problems
Posted: Fri Jan 20, 2012 10:44 am
by Golfather
LOL !
Told ya the box was <beep> !
And you can get better MPG out of a '6 !
Posted: Fri Jan 20, 2012 11:01 am
by HYFR
haha
yes when it happened i thought thats exactly what you said
its rubbish, i mean it wasnt even near the limiter, prob 3/4 up the rev range then it changed by its self!!
Posted: Fri Jan 20, 2012 11:18 am
by Ian_C
Thats not right. Does it change down too if you manually put it in sixth through the SPECS roadworks?
Posted: Fri Jan 20, 2012 11:35 am
by HYFR
i always put it in 7th gear manual mode through the SPEC's & it will hold the gear
but all Manual mode S-Tronics will change down for you when it needs to, to stop you stalling the car !
Posted: Fri Jan 20, 2012 11:46 am
by Ian_C
You can understand the S4 changing up when it runs into the limiter in manual mode - but certainly not 3/4 way through the rev range!!!
Posted: Fri Jan 20, 2012 11:55 am
by HYFR
maybe its a self preservation thing untill it had some more miles on the clock
Posted: Thu Jan 26, 2012 8:43 pm
by RSDave
Possibly a milage thing, (does it need running in
haha, same eninge and box that was in my S5 cab i think... best option for me was to click to box into 'S' mode then click one of the paddles to engage sport/ manual then i had full control, (although it had already covered 16,000 miles)
Good Luck!
Posted: Thu Jan 26, 2012 9:37 pm
by HYFR
Iv already been caught out by it
Got to the top of 3rd coming into a corner, so I click it into 4th to take the corner, bloody car changed up itself a milisecond before I hit the paddle and so the bloody car went into 5th for the corner
Not impressed
Posted: Fri Jan 27, 2012 1:32 pm
by 535dboy
So you are not already hitting the limiter with only 250miles on the clock
Was it warm. Seem to remember something like that on the Rs5 that it would change up early regardless I what I was doing when it was cold?
I know you know better than me but just a thought.
Posted: Fri Jan 27, 2012 3:56 pm
by HYFR
its got 673 miles on the clock now
yes it was warm
Posted: Fri Jan 27, 2012 6:27 pm
by Rick_RS4
you wont have it in 2 weeks so why care
Posted: Fri Jan 27, 2012 9:46 pm
by HYFR
Iv had an RS 5 and that did what it was told in manual mode
Posted: Sun Jan 29, 2012 8:22 pm
by Doug_S2
I''ve only done 150 miles but tested today. In M it stays in the gear between the limits no matter how I drove it. 2009 model though.
Posted: Sun Jan 29, 2012 9:00 pm
by HYFR
Doug_S2 wrote:I''ve only done 150 miles but tested today. In M it stays in the gear between the limits no matter how I drove it. 2009 model though.
interesting ... mine will always change up
