Puncture - new tyre advice
Posted: Wed Dec 22, 2010 11:31 am
by andya
Just had a puncture on the rear right. I say puncture, by the time I realised, the entire inner edge wall of the tyre has split from the reset of the carcass :-/ Looks a bit like a spectacular F1 tyre failure.
Car has done about 9,200 miles and has the original Dunlop Sport Maxx fitted all round.
Will I be ok just replacing the dead tyre with a new Sport Maxx or are there any other suggestions or advice?
RE: Puncture - new tyre advice
Posted: Wed Dec 22, 2010 7:06 pm
by Scotty
Hmmmm tough call as at 9,200 they'll be quite a bit of wear and you shouldn't just replace one due to the quattro.
I've got the same tyres (admittedly on a 2.0T) and although they come out quite well in tests I just don't fine them that hot in wet weather. Not sure what I'd switch to though.
Posted: Thu Dec 23, 2010 5:20 pm
by Pete.S
I'd either get 2 new Dunlops for the rear, or swap all 4. I swapped from the fitted Pirellis after they wore out way too quickly to Michelin PS2s, and amazingly they last longer in 19" guise than the 18"s I had on my B6 S4 - well over 20k miles and I don't hang about round corners
Posted: Thu Dec 23, 2010 5:40 pm
by andya
I had a look at the existing rear tyre and it's still got around 5mm on it. Given that the new tyre only has 8mm of tread I'm not going to spend another £220 to replace a perfectly good tyre.
The new one is exactly the same spec as the old one (Dunlop Sport Maxx GT)
Posted: Fri Dec 24, 2010 11:14 am
by bye bye
Replace both tyres and sell the part worn on Ebay.....with just 9,200 miles you'll get good money....people buy them for track days etc.
I got £120 for 2 almost bald 235/35 19 off my old Boxster from a guy looking for track tyres for his M3.
I'd swap the new tyres on the front too.......
My next set will be Vred Sessantas.......
Mark
Posted: Fri Dec 24, 2010 7:27 pm
by Scotty
andya wrote:I had a look at the existing rear tyre and it's still got around 5mm on it. Given that the new tyre only has 8mm of tread I'm not going to spend another £220 to replace a perfectly good tyre.
Fair enought but do it knowing that it's against all the Audi advice and that that you've got on this forum.
It's said for a reason.
