RS5 Front Brake Pads Required
Posted: Tue Sep 08, 2015 10:29 pm
by xxx_mojo_xxx
Time to replace my front pads after upgrading to the RS5 brakes.
Should I stick with OEM pads or try something else?
Suggestions and web links required pls.
Re: RS5 Front Brake Pads Required
Posted: Wed Sep 09, 2015 8:33 am
by RossDagley
What's your intended use of the car? Road driving or track only or...?
Standard pads are actually pretty good for everyday driving. Ebc yellows work well but dust A LOT. Winmax are awesome but eat through discs and can squeal (and aren't aimed at road use).
Posted: Thu Sep 10, 2015 7:03 am
by xxx_mojo_xxx
Spirited road driving.
Do the ferodo ds2500 come with the wear sensors?
Posted: Thu Sep 10, 2015 8:23 am
by RossDagley
xxx_mojo_xxx wrote:Spirited road driving.
No. And IMO standard pads will be plenty, with the least dust.
Posted: Fri Sep 11, 2015 1:05 pm
by u22mjd
I have a set of Front Brembo RS5 pads I had on for 70 miles before I switched to EBC yellowstuff pads if of any interest currently sat in my shed gathering dust PM if of interest.
Posted: Fri Sep 11, 2015 5:45 pm
by jaygemson
I've tried a few different compounds now.
CL (Carbon Lorraine) RC5+
~£300, supplied to me by Allumy Motorsport
These were fantastic pads, with tonnes of initial bite even from cold and very low dusting. When pushing on they resist fade well and don't go spongy under the pedal when hot. They are reputed to be hard on discs but I believe CL resolved this with their newer compounds, but unfortunately these were very noisy when light braking at low speeds. Otherwise faultless.
Pagid Blue (RS4-2)
~£415, supplied to me by CA Automotive
Much quieter than the CL pads with similar performance traits and low dusting. Really pleased with these and they're currently performing all duties, no need for pad swaps on track days. They do get a tiny bit noisy if they're not 'properly' used for a while, so about once a week after the daily grind I take them out for a proper B-road blast and they're silent again.
OEM Brembo pads
These provided good feel and were totally silent on road, but were dusty and also don't cope with track work - they went very soft and literally melted onto the discs, leaving nasty deposits which needed to be skimmed off. You could run these for daily use and swap out to the more aggressive Pagid RS29 for track days for a more dedicated setup.
Posted: Sat Sep 26, 2015 8:53 pm
by xxx_mojo_xxx
If anyone has a set of spare pads which they are willing to part with give me a shout pls.
