Have of you removed silencers from standard exhaust?
Posted: Wed Jun 24, 2015 12:32 pm
by BugsyM
Hi,
As per the post title Have of you removed silencers from standard exhaust?
I'm looking for a little more noise without loosing the oem look.
Mat
Posted: Sat Jul 11, 2015 11:17 am
by julieng
I heard some people in France removed the front silencer and it makes a great sound after, no drone and oem look.
Re: Have of you removed silencers from standard exhaust?
Posted: Sat Jul 11, 2015 2:58 pm
by Ian_C
A few people on here (and SRS) have removed the front silencer 'suitcase' box and replaced it with a straight through X pipe. Its a great value mod that gives you probably just as much 'voice' as a £1500 cat back resonated Milltek whilst maintaining the OEM look. Magnaflow seem to be the best.
http://www.ebay.co.uk/itm/111414754173? ... rmvSB=true
Posted: Sat Jul 11, 2015 4:25 pm
by julieng
What is the best option : x-pipe or normal pipe to replace front silencers ?
Posted: Sat Jul 11, 2015 5:43 pm
by Ian_C
I'm sure you could have two completely separate pipes in parallel if you wished.
Posted: Sun Jul 12, 2015 4:45 am
by julieng
In fact there are 2 possible options:
1. Remove the 2 Donwpipe Resonator and replace them by normal tubes
2. Remove the Central Resonator and replace it by x-pipe resonated like this one: http://www.magnaflow.com/02product/disp ... mber=11385
Here is the result: https://youtu.be/mHWgYrJ9vfA
What is the best based on your experience
Julien
Posted: Sun Jul 12, 2015 8:15 am
by MikeFish
julieng wrote:In fact there are 2 possible options:
Julien
Or remove both the down pipe and centre resonators? Or will that make it too loud?
Posted: Wed Oct 28, 2020 4:25 pm
by Parkc
Hi. I’m new in here. I have an Rs4 B8.5 and I’ve already done the middle resonator delete and had an X pipe fabricated to replace it.
I’m now considering removing the front resonators and having a H pipe configuration out there instead to make it louder but also hopefully make it drone free.
Has anyone else done this or know if this would work?
