Roc-Euro Cold Air Intake Review
Re: Roc-Euro Cold Air Intake Review
Where's the cold air come from? All I see is a filter sucking dirty hot air from under the bonnet.
Yeah, I did see that but I still wasn't sure if the heat shield seals air coming up from the bottom. Also, I imagine it would be as 'clean' as an actual airbox? Simple set up though, that's commendable.t20ary wrote:Do you see the smaller filter that's attached to the cold air intake ducting and the way the Roc-Euro is designed the heat shield is set up to the bonnet creates a seal when it's closed.bam_bam wrote:Where's the cold air come from? All I see is a filter sucking dirty hot air from under the bonnet.
Sorry but those links don't work
