I'm looking for suggestions for 18" and 19" alloy wheels (ideally OEM) for my S4 B8 (Black Avant), since my original 18" wheels have Winter Tyres fitted.
So far my search is consisting of:
- Rotors (5 spoke) - 8K0601025AR
- Segment 5 spoke - 8K0601025CM
- V-spoke - but do they come in less than 20"
I understand that I need to look for 8.5J / ET43 and a 66.6mm centre bore, but would any other slight variations also fit without needing to modify the arches?
I've seen some Segment versions with different spec such as 8T0601025 T with 9J x 19 ET 33, would these stick out too much?
S4 B8 - 18" or 19" - Alloy Wheel options?
FormativeYears
- 1st Gear
B5 S4 - KO4’d
Re: S4 B8 - 18" or 19" - Alloy Wheel options?
V spoke are available on 19s
Et33 should be ok
Personal opinion. I think 9J x 19 ET 33 look dire on the front of an A4 S4. However, some people love this 'spaced' look. Several people on 246 + SRS have tried these on their S4
Edit - for example
viewtopic.php?f=49&t=94894&p=492267
viewtopic.php?f=49&t=112326
viewtopic.php?f=49&t=99010
http://www.audizine.com/forum/showthrea ... ur-B8-S4-s
Edit - for example
dimitar.tuntov.5
Et33 is fine with stock suspention
dimitar.tuntov.5
I haven’t got pic at the moment only at the front but looks fine to me ! 9x19 Et33 with 255/35
Year old thread
As above, personal opinion, I think that looks completely stupid, it would completely cake the side of the car in the winter/wet, and some mot testers would fail the front wheels protruding from the arches like that
