Require latest 2016 sat nav update for Audi MMI 3G HDD
3.0 V6 24v TFSI - 329 bhp
xxx_mojo_xxx
Post by xxx_mojo_xxx » Sun Jan 10, 2016 3:07 pm
Does anyone know where I can download the latest Audi satnav updates from?
Pls PM me if necessary. Appreciate the help.
P.S. How does one check the map version and what is the latest version?
Thanks,
Mo
Skiptowncat
Re: Require latest 2016 sat nav update for Audi MMI 3G HDD
Post by Skiptowncat » Sun Jan 10, 2016 10:20 pm
Just done mine today.
You'll need k0257 firmware
http://cartechnology.co.uk/showthread.php?tid=12093
xxx_mojo_xxx
Post by xxx_mojo_xxx » Mon Jan 11, 2016 9:30 am
Seems complicated and dangerous. What improvements are there with the firmware and map updates? Are they significant?
Skiptowncat
Post by Skiptowncat » Mon Jan 11, 2016 11:10 am
Depends how often you use the navigation. I use it a lot so like to keep it up to date.
It's actually pretty easy to do on a 3G unit, it's 3G+ that is a bit tricky.
xxx_mojo_xxx
Post by xxx_mojo_xxx » Mon Jan 11, 2016 11:19 am
How do I know if I have a 3G+ unit? Sorry I'm a total noob.
Skiptowncat
Post by Skiptowncat » Mon Jan 11, 2016 2:12 pm
3G+ has online stuff like google maps.
Skiptowncat
Post by Skiptowncat » Mon Jan 11, 2016 2:14 pm
Press "car" button then "info" select settings using the top right button and there should be a menu there called version information.
xxx_mojo_xxx
Post by xxx_mojo_xxx » Mon Jan 11, 2016 10:13 pm
Ok, mine does NOT have Google maps.
Skiptowncat
Post by Skiptowncat » Mon Jan 11, 2016 10:56 pm
Check the firmware version via the steps above
