Playing music via bluetooth
Is this possible to do on my S4 folks. I have a music app on my Samsung Note 2 which gives you the option of playing music via blue tooth but when I hit search it comes up with nothing ie it's not finding the car. Does work with my phone for calls no problem so not sure what's wrong.
Re: Playing music on via bluetooth
Do you have AMI?
If so yes.
If not, no.
If so yes.
If not, no.
Depends which year B8 also. Not possible with all AMI equipped cars out the box.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Re: Playing music via bluetooth
Car is a 61 plate. What is AMI? Forgive my ignorance but I'm quite new to Audis.
Audi music interface
Can you plug in your ipod? If so you can buy a Tune2Air ... Google it.
Damon68 wrote:Car is a 61 plate. What is AMI? Forgive my ignorance but I'm quite new to Audis.
+1 for Tune2Air. Just plug it in to your iPod lead in the glovebox, pair it with your phone, select Media on the car and off you go. Track titles, control via steering wheel, it's that easy.
Just bought myself a Tune2Air for my car - thanks folk....
Plugged into glovebox AMI connector and it paired up quickly and indeed works exactly as if the iPhone was plugged into that AMI cable instead. Outstanding recommendation!
Question though - is that AMI cable permanently powered or does it shut down after a while, ie: will it eventually flatten the battery if left for long enough? I've used other cars instead of the S4 for about 5 weeks and was worried that it might not have started when I needed to use it (at 5:30am yesterday morning). But I needn't have worried, as it sparked up as if it had been parked for 2 days, not 5 weeks. Soooo much better than my C5 RS6 in that regard.
So will this Tune2Air be powered up forever and risk impacting my (till now) perfect battery stability do you think?
Thanks.
Thanks.
Easy way to test.
Just try to pair when your cars locked
- xxx_mojo_xxx
Where's the best place to get this tune2air cable?
Seems it doesn't pair when locked, so I guess it's not powered all the time. Good test, thanks!
Amazon - search for Tune2Air WMA1000, and it's just the Bluetooth module, it needs the Audi AMI cable too.
StandFreeRS4
- 1st Gear
Hi all
I just got the WMA2000 Tune2Air i.e. the one with the usb jack and plugged it into the AMI cable in my glovebox (2013 S4).
My iPhone 5s connects to the Tune2Air but on the MMI screen, it's not showing up. Help!
Current: S4 Avant (B8)
Previous: RS4 Saloon (B7) | M3 (E46) | Honda Civic Type R (EP3)
Yes, I bought the tune2air last week. Works treat with my Galaxy S5. High recommend it.
B8 S4 Black PreFL Avant
Previous: B7 RS4 Sprint Avant, BMW Z4 3.0 Coupe, TT MK2 3.2, TT MK1 225 Coupe, B5 S4 Avant
cheshire_carper
Holy thread resurrection!
I have bought a Tune2air. Does anyone know if you can make it display track information on Android? The music plays but it doesn't have any track titles at all
cheshire_carper
Sent the Tune2Air back. Not a fan of trackless titles and skipping on Android
