Is it normal for the drive select to go back to auto each time the car is turned on? I always use individual and have to cycle through each time.
And a strange one is that when I first get to individual the engine/gearbox isn't in S mode but when I keep cycling (after going thru dynamic) it get the S correct the 2nd time. A bit annoying.
Drive Select
Re: Drive Select
Yep mine does the same. You can use those VAG-COM cables and modify it so it defaults to whatever you want when you first turn it on
B8 RS4: Phantom Black
Previous Motors: | AUDI B8 S4 Avant | BMW E92 M3 | BMW E92 335i N55 | AUDI V8 S5 |
