Boost pressure
Posted: Wed Oct 10, 2012 9:21 pm
by Paulm
Anyone know what boost pressure their RS runs, standard or remapped?
Anyone done logs on VCDS?
What about power. My car is very fast to 5k then it is mental fast. Are your cars the same.
Re: Boost pressure
Posted: Sat Oct 27, 2012 8:55 pm
by Paulm
Not sure if anyone is interested.
Standard 0.7 bar
MTM Remapped 1.4bar Although that is very high. I reckon 1.2bar is prob better and safer.
Re: Boost pressure
Posted: Mon Oct 29, 2012 3:05 pm
by TBl
my 700PS MTM tune (which turned out to be 650PS in reality) was 0.9 bar. I recon 1.4 bar would be above what is achievable on standard engine internals
Re: Boost pressure
Posted: Mon Oct 29, 2012 4:18 pm
by speedfr38ky
1.4 is perfectly safe for these turbos. I once read an article where the guy in charge of the c6 v10 biturbo engine development was quoted as saying " the turbos on the c6 RS6 can release a lot more potential if we allowed them to"...... doug at mrc told me you could run more than 1.4 but then you'd get too much heat and then obviously it becomes counter productive as you lose power rather than gain.
Also MTM guarantee the reliability of their tuning products and develop extensively before release onto the market.
Re: Boost pressure
Posted: Mon Oct 29, 2012 10:32 pm
by Paulm
Thanks for the info lads was beginning to think no-one tuned their cars :)
mine is running the same at around 0.9bar
ok 1.4bar it is then :thumbs:
Re: Boost pressure
Posted: Mon Oct 29, 2012 11:29 pm
by catfood12
I wonder if the likes of MRC rescale the boost bar graph on the dash. If stock it's 0.9 bar full scale, does it still read same, i.e. 1.1 bar or whatever they do for stage 2 would be off the scale. Moot point anyway as there's no reference figures on the dash...
Re: Boost pressure
Posted: Mon Oct 29, 2012 11:33 pm
by TBl
As far as tuning is concerned, I've heard first 1000bhp RS6 C6 is on its way... Will keep you posted
Re: Boost pressure
Posted: Mon Oct 29, 2012 11:47 pm
by Golfather
catfood12 wrote:I wonder if the likes of MRC rescale the boost bar graph on the dash. If stock it's 0.9 bar full scale, does it still read same, i.e. 1.1 bar or whatever they do for stage 2 would be off the scale. Moot point anyway as there's no reference figures on the dash...
Post map, its always off the scale :thumbs:
Re: Boost pressure
Posted: Tue Oct 30, 2012 1:25 am
by Paulm
what about pre-map. where does it boost to on the graph. Only seen mine post map and as you say it's off the scale
Re: Boost pressure
Posted: Tue Oct 30, 2012 4:11 pm
by speedfr38ky
The Boost bar isnt recalibrated post map. It goes to max reading almost instantly.
As long as you let the car warm up before giving it some and get the oil changed every 6K miles on a mapped car all will be fine im sure.
Re: Boost pressure
Posted: Sun Nov 04, 2012 6:20 pm
by perthwaRS6
FWIW, on warming up engine oil, a race mechanic told me critical that dry sump engines get oil warmed up before giving it the beans due to high oil viscosity when oil is cold and high resistance to circulation from the remote oil tank .
Re: Boost pressure
Posted: Sun Nov 04, 2012 6:37 pm
by catfood12
perthwaRS6 wrote:FWIW, on warming up engine oil, a race mechanic told me critical that dry sump engines get oil warmed up before giving it the beans due to high oil viscosity when oil is cold and high resistance to circulation from the remote oil tank .
I'd suggest that on any internal combustion engine, from an RS6 to a 3 cylinder Kubota mower, to warm it up before giving it beans (or cutting super long grass!). I think oil viscosity is less of an issue with today's synthetics, more like letting the steel bore liners come up to temp and expand after a few minutes and restore the clearance around the ally pistones that came up to temp and expanded far quicker !
Re: Boost pressure
Posted: Sun May 04, 2025 10:00 pm
by strayman
Hola alguien me podría decir cuál es la presión de turbo de un rs6 v10 con turbos grandes en 1000 hp
Entiendo que dicen 21psi pero los mlantiene en la gama de RPM
Alguien tiene datos por favor
Gracias
