Condensation
Posted: Sun Aug 19, 2012 5:49 pm
by andy
Anyome else get a small patch of condensation at the base of the windscreen whilst a/c running? Noticed this on and off now and I think it normally happens when I'm not moving very quickly i.e. slow traffic. Patch is can be up to a couple of inches across at times but normally a lot smaller.
Not sure what's causing it and wondered if anyone else has this?
Re: Condensation
Posted: Sun Aug 19, 2012 6:44 pm
by Trups
Its the aircon making the window do that, if its 30 degree's outside and inside its the 15 degree's on the AC it will. change the setting so its on your feet or face and it will be fine.
Re: Condensation
Posted: Sun Aug 19, 2012 7:03 pm
by andy
I assumed it would be the temp difference between outside and in but I thought I would check that this was normal.
Re: Condensation
Posted: Mon Aug 20, 2012 7:00 am
by gdavison
andy wrote:I assumed it would be the temp difference between outside and in but I thought I would check that this was normal.
shows the AC is working, its option code CON and was an optional extra at 500 GBP
Re: Condensation
Posted: Mon Aug 20, 2012 7:54 am
by andy
Haha, think mine has that one fitted then
Re: Condensation
Posted: Fri Aug 24, 2012 9:22 pm
by Streem
Mine does exactly the same.......
Re: Condensation
Posted: Fri Aug 24, 2012 9:24 pm
by andy
Good to know, ta
