Correct rear brake pads
Posted: Sat Aug 16, 2025 7:45 pm
by Limited100
Anyone know if these are the correct rear brake pads?
https://www.ebay.co.uk/p/7058998264
or these?
https://www.ebay.co.uk/p/7058998264?iid=305594597679
I have standard 356 mm brakes, not ceramics.
Re: Correct rear brake pads
Posted: Sat Aug 16, 2025 7:49 pm
by IanH755
Yeap, Ferodo FCP1655H are the correct pads for the rear Steel brake setup. I have a set fitted right now.
https://www.ferodoracing.com/vehicle/ca ... s6-quattro
Posted: Sat Aug 16, 2025 8:01 pm
by Limited100
Thanks but the 2 links should load different - the first is cheaper, the 2nd is for "TRW Caliper".
Posted: Mon Aug 18, 2025 5:21 pm
by IanH755
Both links are the exact same pad, the "TRW" stuff is just some eBay waffle, but either of those two links will fit our rear calipers as both pads are identical.
Posted: Mon Aug 18, 2025 9:33 pm
by Limited100
Ah great, thank you.
