DRC saga
Posted: Thu Oct 17, 2024 6:24 pm
As mentioned elsewhere, my car has a split DRC hose (left front) and another (right rear) that isn't looking too smart so I got hold of a couple of hoses and as it was a nice day thought I'd crack on with changing them.
Left front: Releasing the shock end wasn't too difficult. The other end - the body hard line didn't look good, on closer examination there was a suggestion of a twist to it. The flare nut was tight, not fast, but even with lubrication it was dragging on the line. The new hose fitted to the shock reasonably easily but the other end was a pain - three times it cross threaded so three times I had to take it off again and run a new flare nut through it to deburr the threads.
Right rear (fitted by JCT600 around 8 years back): Again, the shock end wasn't difficult - and it shouldn't have been because I fitted a new shock about 18 months back. Hard line end - line didn't look good and the flare nut had been rounded but I managed to get a flare spanner on it. Wouldn't move. Ah, yes it did - but not easily, by the time I'd got half a turn on it I decided to give up, tighten it again and tackle it another time.
Drained the oil, it sat at -1bar while I made a coffee, so didn't seem to have any leaks. Filling and pressurising seemed to take longer than normal but got there eventually. Checked for leaks and there it was - dripping from the hard line end of the right rear. Depressurised it again, put a spanner on the flare nut and....
Luckily, it's the shortest of all the lines and I have a coil of 1/4" Kunifer along with flare nuts in my garage so tomorrow I'll see what I can make up.
