Problems with the Electronically Controlled Damping system on RS6, C6
Posted: Sun Jun 16, 2024 10:39 am
Hi,
Has anyone had experience in solving problems with the Electronically controlled damping system?
The MIL light came on after fixing the dreaded coolant pipes and changing snapped front springs without removing the DRC pipes but disconnecting the ECD plugs.
It will not reset with VCDS.
Saturday,15,June,2024,16:04:43:00251
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 24.5.0.0
Data version: 20240429 DS355.0
www.Ross-Tech.com
Address 14: Susp. Elect. Labels: None
Control Module Part Number: 4F0 910 376 HW: 4F0 907 376
Component and/or Version: J250 DRC FahrwerH02 0020
Software Coding: 0000000
Work Shop Code: WSC 131071 1023 2097151
VCID: 64C7BC99A75B44B6C7-8030
1 Fault Found:
01769 - Sensor for Vehicle Leveling; Front Right (G289)
010 - Open or Short to Plus - MIL ON
Freeze Frame:
Fault Status: 11101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 204109 km
Time Indication: 0
Date: 2008.04.11
Time: 09:40:11
I can't find much information on exactly how the system works apart from the RS6, C6 study guide.
Removing the connector adds another fault in addition to this one in VCDS.
The left side gave similar problems but were reset after the connector pins were cleaned and the connector re-seated.
There is no label file in VCDS and very little info in the measuring blocks and I think the description in VCDS may be misleading since there is only a motor and hall sensor for the valve position in the damper.
Nothing much in the test blocks either.
It looks to be electrical so may be a broken wire.
Anyone who has had similar experiences please post or send a PM. Any advice appreciated!
www.Ross-Tech.com
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 204109 km
Time Indication: 0
Date: 2008.04.11
Time: 09:40:11
