What's this?
Posted: Fri Sep 16, 2022 11:01 am
by Imola_Sid
Found this is in the glovebox.
I thought it was a phone/a2dp connector but not finding anything on my phone when searching Bluetooth.
Any ideas?
Re: What's this?
Posted: Fri Sep 16, 2022 12:03 pm
by Jim Haseltine
Would have been my first guess. Have you checked the MMI media section to see if there are multiple sources listed?
Re: What's this?
Posted: Fri Sep 16, 2022 12:43 pm
by Imola_Sid
Yup, has the following -
Re: What's this?
Posted: Fri Sep 16, 2022 12:49 pm
by Imola_Sid
This comes up but doesn't connect.
Re: What's this?
Posted: Wed Sep 21, 2022 8:39 pm
by tom4motion
I had one similar and needed a power source via the USB to work.
Re: What's this?
Posted: Thu Sep 22, 2022 4:43 pm
by Doug_RS6
100% will need usb power on 2g mmi system. I fitted a USB port in the glove box
Re: What's this?
Posted: Fri Sep 23, 2022 8:13 pm
by Imola_Sid
Thanks for the replies. Anyway to power it without having cables exposed?
Re: What's this?
Posted: Fri Sep 23, 2022 8:55 pm
by Imola_Sid
Doug_RS6 wrote: ↑Thu Sep 22, 2022 4:43 pm
How did you do this mate?
Re: What's this?
Posted: Sat Sep 24, 2022 8:46 am
by IanH755
I would test this device first as the USB powered Bluetooth device I tried (which looks like yours does) sounded absolutely awful when I tried streaming any music over it. It only came through the left speakers, the volume was very low and it sounded not far off an older AM Radio rather than a nice modern Spotify stream so I'm 100% sure I had a "bad" unit which, being made of Chinese-ium, could be a common theme if it's been left unpowered in your car.
Re: What's this?
Posted: Sat Sep 24, 2022 12:29 pm
by Doug_RS6
Imola_Sid wrote: ↑Fri Sep 23, 2022 8:55 pm
Bought a cheap usp socket. Removed the glovebox and drilled a hole in the side to but the usb socket through. Then connected it to a power source. Think I tapped into something like the glovebox light. Originally soldered it but have since switched it out for a connector as when soldered it technically meant the glove box was permanently attached as the wires couldn't be disconnected.
Re: What's this?
Posted: Sun Sep 25, 2022 7:56 pm
by Imola_Sid
Thanks guys!
