Page 1 of 2
The cheapest RS6 V10 salvaged at 215,000 miles
Posted: Wed Sep 29, 2021 2:33 pm
by welwynnick
Some brave soul bought an RS6 with 215,000 miles from a salvage yard with sackfull of problems, and has started making videos about his presumably long and expensive journey.
I'm not sure where this is going, but it will be an interesting ride.
https://www.youtube.com/watch?v=LL0h6W7 ... dw&index=1
Nick
Re: The cheapest RS6 V10 salvaged at 215,000 miles
Posted: Wed Sep 29, 2021 2:35 pm
by VaudiGR
Seen all the videos so far.
I suspect either a pcv system failure or/and turbos.
What else can cause such a huge amount of oil in the intercoolers?
Posted: Wed Sep 29, 2021 3:16 pm
by welwynnick
Agreed. Would anyone else have bought that car? I think I would, depending on how expensive it was.
Bit surprised by the rust on the rear arches though. I thought Audis were galvanised?
Nick
Posted: Wed Sep 29, 2021 6:06 pm
by Jim Haseltine
Galvanizing doesn't last forever - it's a sacrificial coating really, scratch through to the base metal and you'll get rust.
Posted: Wed Sep 29, 2021 7:49 pm
by welwynnick
Hi Jim, did your intercooler oil problem look the same as this video?
https://www.youtube.com/watch?v=trM9Qt1 ... dw&index=2
Posted: Wed Sep 29, 2021 10:21 pm
by Jim Haseltine
There was one time prior to all the work I've done when it came close - I drained 750ml from the right hose and 250 from the left but it's nothing like that now. What isn't shown in that video is how much continued to drain from the intercoolers and how much stayed in the bottom tanks 'cos the cooler inlet is actually higher than the base of the cooler.
Once I can get some fuel I'll be able to chase my problem a bit more - I have some theories to investigate.
Posted: Fri Oct 08, 2021 5:07 pm
by IanH755
His latest Video showing the issue -
https://www.youtube.com/watch?v=Z8-S3N7YKA0
Posted: Sat Oct 09, 2021 9:42 am
by Jim Haseltine
After some more work just after my last post I was 99% certain that my problem is down to failure of the non-return valves in the pipes between the air boxes and turbo oil return air pipes. I 'freed' them rather crudely by alternately filling them with penetrant and giving them a good smack on my bench for a few minutes. Since then there's been very little oil in the pipes compared to previously.
I ordered replacement pipes a day or so before the latest video was posted - I suspect Audi will be wondering what's going on.
Posted: Sat Oct 09, 2021 9:48 am
by VaudiGR
Are these valves sold with the pipes? What are their part numbers?
Posted: Sat Oct 09, 2021 10:48 am
by Jim Haseltine
Oh yes - you can't buy just the valves.
07L 103 215 T for the right and 07L 103 215 AB for the left.
Not a lot of change out of £200.
Changing the right is long-winded but quite easy, changing the left isn't - as in it takes a fair bit longer and isn't anything like as easy.
Posted: Wed Oct 13, 2021 10:10 am
by adgleeson1978
I’ve been watching this channel for over a year now is a really good look into VAG cars and is well put together I would encourage anyone and everyone to sub
Audi mad man from down under
Adz
MY16 S3
Posted: Wed Oct 13, 2021 4:16 pm
by Jim Haseltine
Supplied defective. Waiting on the local dealership to source a replacement.
Posted: Wed Oct 13, 2021 7:57 pm
by welwynnick
Pathetic. What do they expect you to do? Test every part you buy?
£200 sounds steep, so I looked around. If you search for "aluminium non return valve" in the usual sources you get huge number of options...
Nick
Posted: Thu Oct 14, 2021 9:07 am
by Jim Haseltine
I've been caught out with defective/unsuitable parts a fair number of times over the years so if I can safely test things before fitting I do so. Luckily for both my sanity and my wallet I had the good sense to test these valves as soon as I arrived home - pity I didn't actually do that in the dealer's parts department, a mistake I won't make when the replacement arrives.
RH unit is perfect - open in one direction and airtight in the other. LH unit is open in one direction but in the other direction is only slightly restricted and emits a sound like a hunter's duck call.
Posted: Fri Oct 15, 2021 10:01 am
by don0301
Not totally defective then? :thumb:
