My horn sounds pathetic, just a quiet "peep"
So I ordered a pair of replacement aftermarket horns, but when I took the bumper off today I found a pair of "Fiamm" horns, only one was connected as although the connectors fit they are far too large and fall off easily.
I assume the fiamm horns are not original, can anyone confirm whether these are original or not?
Paul
Original horns
- Phuketpaul
- 1st Gear
Original horns
2010 RS6 plus Avant, MRC Stage 2 747bhp 1059Nm
2008 Aston Martin DBS Volante
2001 Discovery 2
2001 Discovery 2
Re: Original horns
Mine are Bosch and marked up with Audi rings and partnumbers on the back so I assume that they are OE. Having said that, ETKA shows two different sets of horns depending on market (one set mounts with a M8 stud, the other set with a M6).
I'm pretty certain that both sets would connect with the same multiplugs.
- Phuketpaul
- 1st Gear
Re: Original horns
Thanks, I'll test both sets and fit the best sounding with proper connections, anything will sound better than the current pathetic "peep"Jim Haseltine wrote: ↑Mon Mar 08, 2021 10:21 amMine are Bosch and marked up with Audi rings and partnumbers on the back so I assume that they are OE. Having said that, ETKA shows two different sets of horns depending on market (one set mounts with a M8 stud, the other set with a M6).
2001 Discovery 2
2001 Discovery 2
